Sound Stream Amp Install Question - Road Glide Forums
  • 1 Post By Big_gary
post #1 of 4 (permalink) Old 12-30-2015, 03:42 PM Thread Starter
I am planning to install a PN4.520D Picasso Nano tomorrow. I have a wiring question.
I know the amp has to intercept the signal to the speakers. The fronts will be easy. I am going to disconnect the front speaker leads. Make a jumper, so as not to have to splice / cut the harness, to take care of my input. Then run new speaker wire from the output. Please let me know if these isn't the best idea.
My question has to do with the rear channel. Is there any other option besides cutting / splicing into the wire? I can think of no other way. If you have installed an amp and have rear speakers, how did you intercept the rear channel?
Sorry to be dense...just absolutely hate the idea of cutting the harness...but I will if no other choice.
THANKS!
12 Road Glide Ultra - Ember Red Sunglo
98 Heritage Springer - Blue on Black
06 Yamaha FJR1300 - Dark Purplish Blue Metallic
GRider is offline
post #2 of 4 (permalink) Old 12-30-2015, 04:18 PM
09Sharknose's Avatar
There are a couple of options:
1) you can do the same thing you're doing for the fronts meaning run the rear outputs from your radio into the rear inputs on the amp
2) some amps allow for 4ch output with 2ch input in which case you can just flip the output switch to 4ch and Rock on.
09Sharknose is offline
post #3 of 4 (permalink) Old 12-31-2015, 02:48 PM
Since the rear speakers are so far away, I'd just cut the harness. If your dead set against cutting the harness, just run a long jumper and hook up the rear channel like your doing the front. Since your wiring the amp by high level input you won't need a remote power wire either, just battery power & ground.
immo2896 likes this.
Big_gary is online now
post #4 of 4 (permalink) Old 12-31-2015, 08:47 PM
Wheelman38's Avatar
Biketronics makes a breakout harness made for Rushmore head units to access the rear speaker wires w/o cutting wires.
Wheelman38 is offline
No sound after BT355 install Sparky0426 Audio 8 07-27-2016 10:19 AM
JBL GTO638 and Sound Stream PN4.520 D Questions GRider Audio 21 04-04-2016 02:15 PM
Sound Stream/ Polk Audio System Jimready Parts for Sale 5 03-10-2016 06:36 PM
poping sound in speakers after legend install? king04 Troubleshooting for Road Glides 1 06-09-2013 09:55 AM
