Has anyone purchased from Soundz Customz? - Road Glide Forums
post #1 of 6 (permalink) Old 01-05-2016, 09:27 AM Thread Starter
Brianu1's Avatar
I am looking to upgrade my system from the Boom Audio to the Level 3 Soundz Customz system which is a package deal using Focal speakers and the Arc Audio amp. Just wondering is anyone has any experience with them, customer service wise, or warranty wise? Based on this forum it looks like those would be great components for just a 2 channel system. That setup including all the harnesses and brackets/adapters is $700. Seems reasonable.
FLTRX, Black Edge Cut Blade wheels & rotors, RSD Seat, TW-777, V&H Power Duals w/ CFR's, Daymakers, SE A/C, PV tuner, Soundz Customz LV-4 audio, Klockwerks Flare 12" smoke, CD LED's, Progressive shocks, & lots of others...
Brianu1 is offline
post #2 of 6 (permalink) Old 01-05-2016, 09:52 AM
Spazz's Avatar
I have Soundz Level IV system with added 157-2's in my lids and upgraded to Arc XDI 600.4 amp.... Peter is GREAT to work with! YES... all plug and play... tuned prior to you getting everything. Always there to help and answer questions and customer service is top notch.
I will advise you to upgrade your amp at this point. I had a good friend that followed my lead on Level IV with only the 2 channel setup and 125.2.... he later wanted to upgrade to 4 channel and lids. Before his lids got there, he installed the 600.4 and he was blown away by the difference with just the fronts on the 600.4.
Its worth the extra coin now.... ask about mounting requirements while your at it... I bought their inner suport bracket for the 600.4 to fit properly.
Here is a quick video of my Level IV system....
https://www.youtube.com/watch?v=8r_8HAmHOII
BTW... for the 2015/2016.... ( not sure on the 2013 or older ) Talk to Peter on the FLASH INFO and get the specifics. I used the FLASH INFO off their site after alking to him and works great as you can tell from the video. Just touch base with him prior to the FLASH and verify no updates to procedures. I printed it all out and gave it to the tech at HD.
RENO BAGGER AUDIO
Spazz is offline
post #3 of 6 (permalink) Old 01-05-2016, 05:49 PM
I have heard nothing but good coming from Soundz Customz. If you can afford it I would upgrade to level lV. I have used several Focal models and the KRCs are by far their best especially pushed by the Arc 600 amp, the Arc mini doesn't do those speakers justice.
gplatt58 is offline
post #4 of 6 (permalink) Old 01-05-2016, 07:14 PM
hd4cruzin's Avatar
I had Peter install the Level 1 system at Laughlin about 4-5 years ago. Arc 125.2 with Focals. He set up the amp using an oscilloscope and the only problem I had was 2 years later the line level to RCA adapter had a short and I just switched to high level input to Amp and still works great.
He was great to do business with.
2012 FLTRX BBP
hd4cruzin is online now
post #5 of 6 (permalink) Old 01-05-2016, 08:37 PM
13Roadglidecustom's Avatar
Yup. Love mine. Level 5 with level 4 lowers. 6x9 in bags. Rocks.
Hold my beer and watch this!!
13Roadglidecustom is offline
post #6 of 6 (permalink) Old 01-05-2016, 09:52 PM
09Sharknose's Avatar
Hard to go wrong with Focal!
09Sharknose is offline
Soundz Customz Level III bfscratch26 Audio 1 11-22-2015 09:52 PM
Soundz Customz? rhuff Audio 10 07-12-2015 10:20 AM
Biketronics, J & M, Soundz Customz NorthGA Audio 9 03-13-2015 07:00 PM
soundz customz ? saintdaniel Audio 31 01-05-2015 03:15 PM
Another Audio Thread :-) Soundz Customz ppalmerjr Audio 10 09-03-2013 03:43 PM
