RF Speaker Swap, micro sub question - Road Glide Forums
post #1 of 10 (permalink) Old 01-10-2016, 09:48 AM Thread Starter
Jwasielczyk's Avatar
Hey everyone!
I have a 2011 FLTRX..(I know, I know, old school!! haha)
I have 4 RF 6.5 in the fairing, 2 in stock location, 2 facing forks (1 is blown)
Pushed by a PBR300x4
hogtunes lids, with RF 6x9
powered by a PBR300x2
I am looking to up grade all the speakers since 1 is blown... seems logical...
With my amps what speakers could i go with, and make clearance with the RF speaker grills (they're color matched to the bike facing forks)
regarding the micro sub..... I have Top Shop Black Death bags, I was thinking about adding a micro sub, and small amp to the extension, facing the wheel, im trying to keep it below the false floor, has anyone ever tried??
Thanks!!
Jwasielczyk is offline
post #2 of 10 (permalink) Old 01-10-2016, 11:20 AM
09Sharknose's Avatar
For the set facing the forks, I would say look into the Alpine Type R. Shallow, small magnet, great sound for the price, although at 75w/ch, you won't be pushing them hard.
For everything else I would say go Focal.
Out of curiosity, what RF speakers were you able to blow with the PBR 300x4?
09Sharknose is offline
post #3 of 10 (permalink) Old 01-10-2016, 12:20 PM Thread Starter
I only blew 1, rf power 6.5
post #4 of 10 (permalink) Old 01-10-2016, 12:22 PM Thread Starter
Stripclub suggested infinity kappas....his sounded amazing... he had 2 more 6.5 than I did... but that's the way I'm leaning... focal are high dollar and probably worth it... I'm rebuilding my motor this winter with a few hush hush upgrades so I'm kinda doing speakers on a "budget" haha
post #5 of 10 (permalink) Old 01-10-2016, 12:23 PM Thread Starter
4 infinity kappas, plus 2 infinity 6x9 is about 375 on amazon
post #6 of 10 (permalink) Old 01-10-2016, 12:32 PM
You'll be happy with the Kappa's pushed by your PBR's
The way it's been explained to me, the higher the quality of the amp, the higher the quality of the speakers needed to take advantage.
The Focal's are FANTASTIC speakers but I don't think the PBR will bring out the best in them, you'll need to invest in a better amp. Kappa's however will.
Bunker is offline
post #7 of 10 (permalink) Old 01-10-2016, 12:50 PM
stripclub's Avatar
Thanks for the compliment. I was running 8 Infinity Kappas 6.5" along with 1" Alpine tweeters mounted in the fairing below the guages facing me that had two crossovers on them a Alpine BT149 and two Soundstream Nanno PN4.520D amps that were mounted in the tour-pac because with the inner facing speakers in the fairing there was no room to mount those amps there. I also ported the tour-pac speaker pods and added Polly fill for a little extra parking lot bass. Sometimes I wish I still had that bike also. Good luck with your build. Your bike ran and sounded great before, especially with the header you were running.
stripclub is offline
post #8 of 10 (permalink) Old 01-10-2016, 02:13 PM
Keep an eye on your freq range and your gain. That amp in that config shouldn't blow those speakers. Good luck with your speaker selection.
post #9 of 10 (permalink) Old 01-12-2016, 06:12 PM
I believe the pbr x4 is a 4 ohm amp and you have to use a 4 ohm speaker. You would be better off getting another RF power speaker until you can afford a whole new system.
gplatt58 is offline
post #10 of 10 (permalink) Old 01-12-2016, 07:17 PM
You are correct. I think the Kappas mentioned above are 2ohm.........they'll blow your PBR 300x4. The PBR 300x2 is 2 ohm stable though. You could switch the rears to the 300x4 and run the fronts in parallel (all four 4ohm speakers), off the 300x2.
JL Audio Sub from Hells Foundry 'Trick Audio 2 11-08-2012 07:28 PM
The "SUB" question again..... Brewiz Audio 2 04-28-2012 09:12 PM
RF PBR300x4 amp and RF speakers? GLYDDN11 Audio 2 02-02-2012 09:46 PM
Oldy's, Tour packs with sub, stretched bags, fenders DED HD Audio 6 02-09-2011 05:02 PM
