need another amp - Road Glide Forums
 4Likes
post #1 of 11 (permalink) Old 01-13-2016, 09:58 PM Thread Starter
gsbuick65's Avatar
need another amp
my alpine ktp445u that i installed 08/12 has kicked the bucket, could using 2 & 4 ohm speakers caused any damage? what a good amp to replace it with? im thinking rockford pbr300x4.
Mike Southaven Ms. 2011 RGU merlot, Rinehart true duals, s&s 570 cams, Power Vision stage 1 a/c, Madstad shield, J&M 7 1/4's, Alpine KTP445U amp, CVO lowers.
gsbuick65 is offline
post #2 of 11 (permalink) Old 01-14-2016, 08:59 AM
Cerwin Vega B4. I have the B2 and it has some serious power for being so small
phillyfan1 is offline
post #3 of 11 (permalink) Old 01-14-2016, 09:15 AM
OneSlickGlide's Avatar
need another amp
Look into the arc moto600.4. Awesome amp and will fit inside the fairing.
Khaotic likes this.
OneSlickGlide is offline
post #4 of 11 (permalink) Old 01-14-2016, 10:50 AM
09Sharknose's Avatar
Yes using 2 and 4 ohm speakers together could have caused damage depending on how they were wired and the specs of the amp.
PBR 300x4 is 4 ohm only.
Arc Moto 600.4 and Cerwin vega B4 are 2ohm stable.
If you don't know about wiring audio up, let someone that does do it. Between blown speakers and amps, it can go south in a hurry!
Good luck.
09Sharknose is offline
post #5 of 11 (permalink) Old 01-14-2016, 02:49 PM
BadBagger08's Avatar
I'd stay away from anything made by Rockford, I see to many people selling them after they have been RMA'd twice.
I've been running the ktp445u for 2 years now no issues, I have it running 2 JL 6.6's and 2 JL 1" tweeters.
For my rear I'm running a JL 400/4 Bridged to to JL 8.8's
I'm not a expert but I would run either 2ohm or 4ohm speakers off 1 amp, I wouldn't mix and match on the same amp.
Jim Frederick
Forum Member discounts. Must be a member. Please PM me or Email me through my website to receive discount
BadBagger08 is offline
post #6 of 11 (permalink) Old 01-14-2016, 09:43 PM
I had the pbr 300x4 pushing 4 RF speakers and the sound was ok but going down the freeway forget about it. I have tried many amps and speakers and I finally went all Biketronics and It rocks going down the freeway and waranteed for life. Good luck.
gplatt58 is offline
post #7 of 11 (permalink) Old 01-15-2016, 12:56 AM
MightyWhitey's Avatar
Just bought myself a new Diamond Audio Micro4 600watt. Installing it tomorrow. Been running a small soundstream with Polk MM6501 in factory location and MM651 coaxial in the inner fairing. I'll let you know how it works out.
gsbuick65 likes this.
MightyWhitey is offline
post #8 of 11 (permalink) Old 01-17-2016, 09:28 PM
JMJOHN
JMJOHN's Avatar
J&M ROKKER amps are very dependable, will put out alot of power, will work with 2 or 4 ohm speakers, and carry a lifetime warranty to the original purchaser ,,,,,(((see J&M ROKKER Series Components for Harley Baggers ,,,,,,,
JMJOHN ----
JMJOHN is offline
post #9 of 11 (permalink) Old 01-18-2016, 10:23 AM
cobra206's Avatar
I have the j&m rokker amp with a set of their 71/4 speakers upfront and a set of hertz deci 6x9 in my saddle bags ( hertz speakers @ 4ohm and j&m @ 2ohm)... I can cruise the highway at 85 with a half helmet, ear plugs in and the volume not at full volume and hear everything crystal clear. I'm using the AV Aquatics head unit... Just my opinion from actual use...
cobra206 is offline
post #10 of 11 (permalink) Old 01-18-2016, 10:55 AM
I've heard some really good things about this amp, and the fact it will fit in the fairing has me considering it seriously.
Another "I Dropped My Bike" Post. [emoji21] JDisMe General Off-Topic Discussions 22 08-19-2017 11:52 PM
Another transmission problem need help on blackbart36350 Troubleshooting for Road Glides 18 09-30-2013 12:48 PM
Need input, SEPST or another T-Max DarbinCo ECM/Fuel Management systems 13 04-26-2012 11:53 AM
Anyone Need Another Hobby?? FL Knifemaker General Off-Topic Discussions 3 02-22-2012 06:01 PM
Do I need another dyno?? devilfishlane *General Road Glide Discussions/Pictures 1 01-11-2011 05:14 AM
