Soundstream PN4.1000D install - Road Glide Forums
post #1 of 4 (permalink) Old 01-21-2016, 03:11 PM Thread Starter
Will a Soundstream PN4.1000D fit inside the fairing by the glove box on a 2012 Road Glide? I want to mount one on each side so I can't use the top of the head unit.
ep120794 is offline
post #2 of 4 (permalink) Old 01-21-2016, 08:17 PM
MightyWhitey's Avatar
I'm relatively certain. I will do my absolute best to remember to stop by in the morning and double check for you. Fairing is already off and I just took this amp out. It will also fit behind an after market media player like a Sony marine Bluetooth in the metal radio mount. I have read that some people have had some issues but I really liked the little amp. It's not pushing its advertised wattage but it's a potent little guy for the size. I was running one set Polk MM6501 2.7ohm component and one set Polk MM651 2.7ohm coax on one of these and it was great at freeway speed up till full blown max it would start to overload a little but then I wear earplugs and rail the stereo wide open all day. I took it out still working well though. Just wanted a bit more. I say you can't beat the price though. Not sure about 4ohm or bridging it. Good luck with your install.
Doohhhh!!! I thought I read st4.1000 Sorry. Need to quit drinking and browsing this forum. Might save me money too.
MightyWhitey is offline
post #3 of 4 (permalink) Old 01-21-2016, 08:23 PM Thread Starter
Are you sure we are talking about the same amp? This amp is 10.5 inches long. It is the Picasso Nano PN4.1000D. I've seen reliable bench tests that show almost 150 watts per channel.
ep120794 is offline
post #4 of 4 (permalink) Old 01-21-2016, 08:37 PM
I edited my post. I read some letters in your title that weren't there.
Rushmore Road Glide & PN4.1000D ahern Audio 2 06-04-2018 08:32 PM
SS pn4.1000d in 15 RGS jp374 Audio 4 04-14-2016 06:57 AM
Ss pn4.520d VS ss st4.1000d sjohn1024 Audio 9 02-27-2016 09:35 PM
SoundStream PN4.1000D OneSlickGlide Audio 2 08-10-2015 06:41 AM
Soundstream ST4.1000D MightyWhitey Audio 21 07-22-2015 04:25 PM
