Hd1bt - Road Glide Forums
post #1 of 8 (permalink) Old 02-03-2016, 10:18 AM Thread Starter
rdrnr03's Avatar
Hd1bt
Anyone that has this installed, can you tell me after connecting Bluetooth the first time does your phone connect automatically every time after that.
rdrnr03 is offline
post #2 of 8 (permalink) Old 02-03-2016, 10:31 AM
PGR
PGR's Avatar
I tried the BlueTooth on mine by pairing my Zumo 660. It paired every time, but for some reason the older version of bluetooth on the 660 didn't want to play well. The sound quality wasn't as good as I had hoped.
I'm assuming you are using your phone for music? If so, I recommend an iPod. The USB to an iPod plays flawlessly, displays the song, and charges the iPod. Or if you want to go cheap, a thumb drive works well too.
Ron..........................
PGR is offline
post #3 of 8 (permalink) Old 02-03-2016, 01:01 PM Thread Starter
rdrnr03's Avatar
Does this radio come with the adaptor that you drill into the glove box?
rdrnr03 is offline
post #4 of 8 (permalink) Old 02-03-2016, 02:47 PM
PGR
PGR's Avatar
That's separate..... but you can get it here
PGR is offline
post #5 of 8 (permalink) Old 02-03-2016, 03:34 PM
mocotom's Avatar
I have the Aquatic Av and am very pleased with it, about same price as the Jensen and is also waterproof. It has a watertight internal tray for phone, ipod,or thumb drive. Just an alternative to look at if you haven't already purchased the Jensen
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #6 of 8 (permalink) Old 02-03-2016, 03:47 PM
PGR
PGR's Avatar
I almost bought the Aquatics AV, but found out that it only had 2 channel output. Since I have a 4 speaker system the HD1BT fit my needs with front and rear, in my case upper and lower RCA outputs, to my J&M amp. It'll rip your face off at 1/2 volume
PGR is offline
post #7 of 8 (permalink) Old 02-03-2016, 05:50 PM Thread Starter
rdrnr03's Avatar
I have looking at both, but the Jensen will match all my gauges being they are all red.
rdrnr03 is offline
post #8 of 8 (permalink) Old 02-03-2016, 06:25 PM Thread Starter
rdrnr03's Avatar
Thank you.
rdrnr03 is offline
Anyone using the Jensen HD1BT audio? jprider4life Audio 28 06-24-2018 04:53 PM
Jenson- HD1BT craig demel Audio 20 02-28-2015 03:08 PM
Jensen HD1BT won't hold clock setting and other issues? chevjerico Audio 10 02-16-2015 07:02 AM
Jenson- HD1BT anybody? Boozefighter Easy Audio 12 10-11-2014 10:59 AM
