I need a speaker upgrade! - Road Glide Forums
 5Likes
post #1 of 19 (permalink) Old 02-04-2016, 08:08 PM Thread Starter
BlkRat's Avatar
So I have a new to me 2013 RG Custom. I want to upgrade the fairing speakers with a set of 6.5s and install an amp. I am looking to spend $350 or less. I was thinking of a set of component speakers and replacing the thermometer and volt gauges with the tweeters.
I've been reading the audio section of the forum, and holy hell is there a lot of info, but I've yet to come across anyone using tweeters in place of the gauges.
Any info would be highly appreciated!
BlkRat is offline
post #2 of 19 (permalink) Old 02-04-2016, 08:39 PM
ia15rgs's Avatar
Good luck. I'm looking at 900 from soundz customz. I hear it's great stuff
ia15rgs is online now
post #3 of 19 (permalink) Old 02-04-2016, 09:12 PM
09Sharknose's Avatar
I've used the tweeters in the place of the gauges. What do you want to know about them?
09Sharknose is offline
post #4 of 19 (permalink) Old 02-04-2016, 09:26 PM
the88virgnian's Avatar
Gonna need more than 350. Low end 6.5 will run ya 100 for a pair and the bullet style tweeters a little more. You can get a low end amp for right around 100 as well. That's not counting install or other components to let your HU and amp play nice with each other
brhodea likes this.
2013 RGU BBP. Detachable Tour Pack, aftermarket slip ons (no name), Wild 1 WO612s, Avon Cushion Grips, 13" Madstad, Kenwood Excelon x799, 8x DD Speakers (4x VO-M, 2x CXS 6.5, 2x B3), Diamond Micro 4v2 Amp.
the88virgnian is offline
post #5 of 19 (permalink) Old 02-04-2016, 09:39 PM
Polk audio 6.5 marine speakers an a Rockford fosgate mini amp pbr300x2. Will blow your mind compared to stock. An. Will only set u back about 300 bucks
Jbglide is offline
post #6 of 19 (permalink) Old 02-05-2016, 04:52 AM Thread Starter
BlkRat's Avatar
I was looking at the thread about the JBL 638s last night this got me thinking. Here's the speakers I was looking at.
https://www.amazon.com/dp/B0017LFSXU..._91hTwb077B0ST
I was hoping someone could tell me what speakers will fit in the holes for the gauges without being too big or too small.
I was thinking of a Soundstream 2 channel amp and both the amp and speakers would be much less than $350 but I figure if I needed wiring harnesses or other stuff I would still have the funds for this project
Also, I've read a lot about guys having the stealer do a flash upgrade. I have an FLTRX with the HK radio, but not the navigation so would the flash still apply?
Thanks!
BlkRat is offline
post #7 of 19 (permalink) Old 02-05-2016, 09:05 AM
You won't need a flash with the 13 head unit. That only applies to bikes with the rushmore head unit (14 and up). If you want some input about the JBL 638s, find @Swomack on this forum. Dude is SUPER helpful and won't steer you wrong. I don't have any experience with those speakers, so can't say much on them, but I know they will fit in the speaker pods with no issues. You will, however, need to buy speaker ring adapters since those are 6.5 inch speaker and the stock is 5.25. Sound Stream is a good amp for those wanting to save money. I'm running one now, and will purchase another this spring when I bump up to an 8 speaker set up. The Picasso Nano is the best bang for the buck lineup they have. You can find those amps on ebay for right around 100 bucks all day. You will need a line out converter so you can connect your stock head unit to the amp (link below). If anyone else has a line out converter that is better than the one I found, feel free to chime in.
post #8 of 19 (permalink) Old 02-05-2016, 09:22 AM
neverdone's Avatar
BlkRat pm sent
neverdone is offline
post #9 of 19 (permalink) Old 02-05-2016, 12:22 PM
Swomack's Avatar
Robot Check
SWomack here
The JBL's are a great 3 way loud speaker for sure. Way better IMO then the stock speakers. I am running them on my. 2015 RGS with just the head unit and they sound great. I have included a YouTube video if you want to listen to what they sound like. If you have any other questions just PM me. If you add an amp these JBL's will be even that much better.
Swomack
http://youtu.be/BZmWdW3sUTs
WSL91 likes this.
My Gallery / Click Below Link
Swomack is offline
post #10 of 19 (permalink) Old 02-05-2016, 12:49 PM
Root76's Avatar
Robot Check
Do you need just ONE line out converter, or two, or four? If adding a 4ch amp to an Ultra, do I need one converter to the front speakers and one to the rear? The pic looks like the converter only has two wires. Thanks
Midnight Pearl 2013 CFR pipes Khrome Werks handelbars
Root76 is offline
Fairing removal/install for speaker upgrade Tek74 Aftermarket Accessories 17 06-23-2014 09:57 PM
Need speaker upgrade... Any advice? Jimb416 Audio 11 06-18-2014 10:47 PM
JM 7.25 Speaker Upgrade system for 06-11 Batwings RIDERED67 Classifieds Archive (3 months old+) 4 04-19-2011 05:37 AM
Speaker upgrade mark_bert Do-IT-Yourself 44 02-16-2011 06:58 PM
amp and speaker upgrade Autobred Aftermarket Accessories 26 08-16-2010 01:57 PM
