Question about amping tour pak - Road Glide Forums
post #1 of 3 (permalink) Old 02-06-2016, 07:30 PM Thread Starter
SurlyBoy's Avatar
I upgraded the front speakers on my 2012 Ultra to the hawg-wired four-in-the-face setup. So now I can barely hear the rear speakers. I know that all the best effect comes from the front but my minor ocd doesn't like the idea that the rears are there but not pulling their weight.
I sometimes remove the tour Pak and although I don't use the intercom I'd like to leave the wiring intact for now. That might change if I swap out the head unit.
So, my question is, can I install a small amp inside the tour pak and run the power wires back to it with a quick disconnect in the line? There's some room in the rear corners for a compact amp where there are bump outs in the liner. I've already removed the rear antennae so there's nothing in the corners.
For the speaker connections I'm thinking l can disconnect the speakers inside the pods and extend them inside the pak to the input side of the amp. Then run the outputs back to the speakers. That would mean I can take of the tour pak using the existing disconnects at the speaker pods and an additional disconnect for the power wires.
SurlyBoy is offline
post #2 of 3 (permalink) Old 02-06-2016, 09:34 PM
09Sharknose's Avatar
I have a hawgwired RS 400 amp in my tourpak to power my subwoofer. So the answer to your question is yes. I used a boat setup for my quick disconnects.
09Sharknose is offline
post #3 of 3 (permalink) Old 02-07-2016, 10:53 AM Thread Starter
SurlyBoy's Avatar
Thanks. I whipped up a quick diagram to help explain it a bit better.
Follow up question. Since each amp will be on its own speaker circuit I presume I shouldn't have to worry too much about equalizing the amps?
SurlyBoy is offline
Want to trade my chopped tour pak for a King Tour Pak sloride Parts for Sale 4 05-15-2015 10:02 AM
need a tour pak backrest to fit a chopped pak burgies13roadglide *General Road Glide Discussions/Pictures 3 04-21-2015 09:05 PM
Metalsports tour pak rack on a '14 tour pak? longrides Aftermarket Accessories 0 11-06-2014 07:43 AM
metalsports tour pak rack on a 14 tour pak? longrides Aftermarket Accessories 0 11-05-2014 09:15 AM
WTB King Tour Pak or Chopped Tour Pak- BLACK jimmyray11349 Classifieds Archive (3 months old+) 0 06-03-2011 10:29 AM
