DIY Stereo Install help - Road Glide Forums
 3Likes
  • 2 Post By Khaotic
  • 1 Post By wevsspot
post #1 of 9 (permalink) Old 02-08-2016, 02:37 PM Thread Starter
I am installing a SONY DSX-MS60 in my 15 RG. Do i have to buy a connector to be able to still use the handlebar controls? Every one that I find is for 2013 and below I cant find anything for the 2015 RG.
soup22 is offline
post #2 of 9 (permalink) Old 02-08-2016, 03:00 PM
Khaotic's Avatar
If Biketronics doesn't make one it probably does not exist yet.
Big_gary and anonymous_1 like this.
2016 FLTRXS 120ST, SE Elite Heavy Breather, D&D Boss Boarzilla, Bandit Sportsman Clutch, Factory47 16" Malo and Arc Audio MPAC 6.
Khaotic is offline
post #3 of 9 (permalink) Old 02-08-2016, 03:40 PM
wevsspot's Avatar
Yes, you will need a module to enable function of the handlebar controls. You can use an inexpensive one and be frustrated (think Metra) or you can bite the bullet and get a complete kit that does exactly what you want. However, the Biketronics stuff is pricey;
BT1014 RetroRadio Install Kit - Biketronics Inc
wevsspot is offline
post #4 of 9 (permalink) Old 02-08-2016, 05:41 PM Thread Starter
[QUOTE=wevsspot;3171626]Yes, you will need a module to enable function of the handlebar controls. You can use an inexpensive one and be frustrated (think Metra) or you can bite the bullet and get a complete kit that does exactly what you want. However, the Biketronics stuff is pricey;
BT1014 RetroRadio Install Kit - Biketronics Inc[/QUOTE
Yeah thats what i was worried about...Do I really need the hand controls right off the bat or is this something I can do ata later time once I can afford the Biketronics module?
soup22 is offline
post #5 of 9 (permalink) Old 02-08-2016, 06:50 PM
wevsspot's Avatar
Have you already purchased the head unit, mounting brackets etc.? Are you upgrading the speakers and adding an AMP as well?
Those might seem like irrelevant questions, but I'm asking because it would help to know your end game.
While an aftermarket head unit is something a lot of folks do, it's not usually one of the first audio upgrades. Adding upgraded speakers and an AMP paired with the factory head unit often gives results that most everyone is happy with.
wevsspot is offline
post #6 of 9 (permalink) Old 02-10-2016, 09:47 PM Thread Starter
yeah I am replacing the head unit and adding a 600w amp and hertz speakers
soup22 is offline
post #7 of 9 (permalink) Old 02-12-2016, 09:55 AM
wevsspot's Avatar
Nice
You'll definitely want the Biketronic's 2014+ installation kit then. It comes with all you need to install and have everything functional afterwards. Double check for compatibility with the stereo that you've chose.
Good luck.
anonymous_1 likes this.
wevsspot is offline
post #8 of 9 (permalink) Old 02-12-2016, 11:17 AM
Hawgwired used to have interfaces for Sony products to interface with the controls. They may be another option.
303RG is offline
post #9 of 9 (permalink) Old 02-17-2016, 06:32 AM
Spazz's Avatar
There is another company supplying a 'full kit' with hand controls and takes care of the digital display you will lose access to.... SoundzCustomz has a complete kit with digital display for you EITMS and oil PSI and I believe will take care of the security flashing on your dash caused by removing the factory HU....
This kit is also for the Road Glides.. even though they talk only of the batwings... I called them...
https://youtu.be/zbMznLWzJrI?list=UU...qZjME98QNQ28fg
RENO BAGGER AUDIO
Spazz is offline
DIY Install of Oberon Adjustable Clutch Lever paid4c4 *General Road Glide Discussions/Pictures 31 10-27-2018 03:19 PM
DIY Milwakee 8 High-Flow Air Cleaner Kit Install InlineR Do-IT-Yourself 7 01-07-2017 02:25 PM
directional noise from stereo after LED tailight install gja Lighting 1 04-02-2012 04:04 PM
My 107 build and stereo install w/pictures (long) Garcou Engine Related 11 02-18-2011 10:18 AM
Aftermarket Stereo Install ?'s jbrawkus Aftermarket Accessories 25 08-26-2010 06:13 PM
