PBR300 and Line Out Converter - Road Glide Forums
post #1 of 3 (permalink) Old 02-13-2016, 04:42 AM Thread Starter
BlkRat's Avatar
For those rung the RF PBR300X2, are you using a line out converter? Is it necessary to use one?
BlkRat is offline
post #2 of 3 (permalink) Old 02-13-2016, 07:59 AM
09Sharknose's Avatar
If you have a 15 or 16, you probably need one. Otherwise, no. The PBR is the only amp I've ever used that sounded WORSE using RCA input than speaker level input. Never could get the distortion out using RCAs. Jmo.
09Sharknose is offline
post #3 of 3 (permalink) Old 02-13-2016, 08:06 AM Thread Starter
BlkRat's Avatar
Thanks SharkNose. I will set it up without it and see how it sounds.
BlkRat is offline
DSP or Line in converter dozer23 Audio 1 03-29-2017 07:23 AM
Kappa 62.11i and pbr300 Liquidr1 Audio 43 02-07-2015 07:58 PM
RF PBR300 data sheet comparison FAQ h-donut Audio 29 10-23-2013 02:52 AM
fresh install, 2 x pbr300, 4 x mm651 W_D_R Audio 9 12-17-2012 10:02 PM
Arc 125.2BX vs RF PBR300 InMotionJosh Audio 3 11-09-2011 03:24 PM
