Antenna, go with a hidden or can I remove it? - Road Glide Forums
 4Likes
post #1 of 18 (permalink) Old 02-16-2016, 09:44 PM Thread Starter
Mooseinthetub's Avatar
Hey all, ive got a 15 RGS and im not a fan of the radio antenna as im sure none of you are. I know there are a few options available to change it. I can go shorter, re-locate it or go with a hidden one. Im considering all 3 but was also wondering if I could just get rid of it completely. I never use the radio be it FM, AM or the weather band. I just use bluetooth. Would it interfere with anything else like the GPS? If I had to choose one I would like to go with a hidden one, but dont wanna pay the dealer price for a couple feet of wire. Any advice or opinions are welcome, thanks!
Mooseinthetub is offline
post #2 of 18 (permalink) Old 02-16-2016, 09:49 PM
UT_Larry's Avatar
I went with hidden on my 2015 RG. Had the dealer install along with garage door opener & led lights so they would be covered by warranty. Had to be done within the first sixty days.
UT_Larry is offline
post #3 of 18 (permalink) Old 02-16-2016, 10:01 PM
army12b's Avatar
I myself just rerouted the antenna, only took 5 mins, only needed to purchase a plug for the whole, at dealer cost was 2 bucks. Pretty cheap option.
army12b is offline
post #4 of 18 (permalink) Old 02-16-2016, 10:58 PM
! rock103 !'s Avatar
I just relocated mine. But you could remove it without harm. Gps has its own antenna in the fairing.
USMC 1990-2000 (0311/6017)
! rock103 ! is offline
post #5 of 18 (permalink) Old 02-17-2016, 12:14 AM
joeker67's Avatar
I hear a lot of different things about this one for use of the radio but if your not using it don't worry. I still like to have the radio for local weather and traffic updates. if your going to keep it go with the hidden antenna.
2016 RGS, Stage one with Screamin Eagle Street Cannons.
joeker67 is offline
post #6 of 18 (permalink) Old 02-17-2016, 06:28 AM
SteveH's Avatar
Hid the antenna. Real easy, 15 minutes.
SteveH is offline
post #7 of 18 (permalink) Old 02-17-2016, 07:38 AM
If you do decide to hide it, and since you don't use radio much, no sense in spending money on a hidden antenna. Do this and save yourself the money and still have radio capability should you ever need it or change your mind.
https://m.youtube.com/watch?v=iJa83AUV7vs
post #8 of 18 (permalink) Old 02-17-2016, 08:39 AM Thread Starter
The video of the guy hiding it himself looks like the road im gonna go down. If I get the extra few bucks for the hidden one in the fairing ill get it. Until then hiding the stock one, thanks all.
post #9 of 18 (permalink) Old 02-17-2016, 09:09 AM
Khaotic's Avatar
I installed one of these because I run a tourpak occasionally and rarely listen to radio.
Swomack likes this.
2016 FLTRXS 120ST, SE Elite Heavy Breather, D&D Boss Boarzilla, Bandit Sportsman Clutch, Factory47 16" Malo and Arc Audio MPAC 6.
Khaotic is offline
post #10 of 18 (permalink) Old 02-17-2016, 09:18 AM
Just a suggestion, if you ever decide to go with the hidden antenna and have or will add an AMP you may not get very good reception with an AMP/hidden antenna combo. With some AMPs and the use of a hidden antenna your reception could be reduced to just about nothing. It happened to me and others I know of as well.
FLTRXS18 is offline
Some go Black Some go Chrome I go my way BACA POPEYE *General Road Glide Discussions/Pictures 66 06-21-2019 09:58 AM
Hidden Antenna? Wes10RG Aftermarket Accessories 11 10-25-2017 10:00 AM
Remove Rear Antenna- Add Hidden Antenna- Hurt Reception? scottrgs Audio 4 09-06-2017 10:34 AM
Remove Antenna Studs TourPak Gary R Do-IT-Yourself 1 04-05-2015 03:00 PM
How do you remove the radio antenna cable? NoChute Troubleshooting for Road Glides 11 05-28-2011 06:28 AM
