Lower Speakers and Heavy Breather - Road Glide Forums
post #1 of 16 (permalink) Old 02-17-2016, 11:18 AM Thread Starter
I looked around and didn't see this question specifically asked or answered so I'm asking.
Will the speaker pods in the lowers fit along with a heavy breather (on and ultra)?
I'm going to upgrade the noise, but I'm not sure how just yet. I don't really want to cut my own inner fairing, so I'm thinking maybe I'll add speakers to the lowers and amp the front 4 and just move the front 6.5s (2ohm) to the rear, so the 4 channel amp (4ohm) would power 4 speakers up front and the stereo would power the rears. (I personally don't think the rears matter, but I'm already running 6.5s upfront from the stereo so no point in throwing them away)...
SquirtRGU is offline
post #2 of 16 (permalink) Old 02-17-2016, 11:20 AM Thread Starter
I found answer to this, turns out if you spell things correctly your search results are much better...
hifiho likes this.
post #3 of 16 (permalink) Old 02-19-2016, 08:13 PM
thedude's Avatar
I was going to try this on my 13. You can get it to fit but it looked like with the vibration it would hit the grill. Never started it up to be sure but it was tight.
thedude is offline
post #4 of 16 (permalink) Old 02-20-2016, 08:22 AM
skratch's Avatar
i would say no. I run a heavy breather with lowers. with the stock filter, it will not fit. with the compact filter, it will fit and give you about 1/4'' clearance. add the speaker pods into the lowers and I think the grill is going to stick out too far.
skratch is offline
post #5 of 16 (permalink) Old 02-20-2016, 08:25 AM
RGKen's Avatar
Not to mention that even if it did fit, it would cover up most if not all of the sound from that speaker rendering it useless. Just use an A/C that works with lowers and be done with it. Plenty out there that perform just as well as the heavy breather anyway.
2018 FLTRXS
RGKen is offline
post #6 of 16 (permalink) Old 02-20-2016, 12:40 PM
09Sharknose's Avatar
One of the guys at Horny Toad opened up a new compact filter and tried to fit it on my '13 with lower speakers. It wasn't even close to fitting on mine and I use the Harley speaker pods and Harley speaker grills.
09Sharknose is offline
post #7 of 16 (permalink) Old 02-22-2016, 09:34 AM
Stick_FSMC's Avatar
As has been stated, it's pretty tight clearance with the SE Heavy Breather and the Lowers on an Ultra.
Stick
USAF 1980-84
Stick_FSMC is offline
post #8 of 16 (permalink) Old 02-25-2016, 09:14 AM Thread Starter
I've got a bit more space on mine... but it will not work anyway.
I have the heavy breather for looks, performance wise it isn't any different than anything else.
For now I opted to jump amp the 2 front speakers. I'm not to excited about old jumpy hands me, cutting holes into my fairing, so maybe next year I'll shell out the $$$ to have it done by the pros...
post #9 of 16 (permalink) Old 02-25-2016, 06:25 PM
The pic only shows the glove boxes. The compact breather will fit with the glove boxes. The OP is asking about clearance with speaker pods. And the answer is a resounding no with the HD speaker boxes.
post #10 of 16 (permalink) Old 02-25-2016, 07:31 PM
Stick_FSMC's Avatar
That's what I was trying to convey. There is ABSOLUTELY no room for speakers with the Heavy Breather. There's barely room for the lowers and that is using the shorter air filter.
I apologize if I was not clear earlier.
Stick
USAF 1980-84
heavy breather air in take w/ speakers in the lower fairing? cabohman Audio 21 07-21-2018 08:19 AM
WTT-Black Heavy Breather for Chrome Heavy Breather MAG150 Parts for Sale 1 01-26-2014 05:15 PM
HEAVY HEAVY rains now speakers are not working well rob883 Audio 6 06-18-2013 01:32 PM
Heavy breather w throttle body cover and filter cover Sinnister Parts for Sale 4 04-20-2013 08:30 AM
Lowers and SE heavy breather on CVO Sparkles Equipment-RG 8 01-10-2013 05:54 AM
