Adding lowers and tour pak speakers - Road Glide Forums
post #1 of 2 (permalink) Old 02-23-2016, 12:40 PM Thread Starter
griswold's Avatar
Currently running soundstream pn4.520 amp with kappa 62.11i up front and 693.11 in the rear. Looking to add another 4.520 amp to power speakers in the lowers and tour pack. Would I run into any issues if I ran a set of HCX 165s (or any other 4 ohm) in the TP and lowers since they are on their own amp? Or am I better off trying to keep the whole system 2ohm?
2010 FLTRX, 2003 FXDX, 1983 XLH1000, 1975 FLH
griswold is offline
post #2 of 2 (permalink) Old 02-23-2016, 03:45 PM
If you're running the additional speakers on their own amp than you can go with 4 ohm, but if you're going to install an 8 speaker system I'd upgrade everything and go 4 ohm all the way around and find big power to push it with. Looking at the specs for that amp (assuming you'd use the same one) it only pushes 100w at 4ohm.
roadie13 is offline
Adding Speakers to '16 RGU Lowers (Rushmore) MontyMoose Audio 0 06-26-2018 08:34 PM
adding a HD king tour pak SEUGOT1 Equipment-RG 5 06-13-2018 08:13 AM
Adding King Tour Pak (with lights) to a Special psrumors Tech Area 15 02-24-2018 01:04 PM
Adding Tour Pack Speakers to 2013 RG CVO Warzone Audio 1 11-15-2015 11:58 AM
Lowers, lowers and more lowers Garemlin *General Road Glide Discussions/Pictures 57 05-11-2010 09:18 PM
