Installing Speakers In Factory Lower Fairings - Road Glide Forums
post #1 of 12 (permalink) Old 02-24-2016, 12:10 PM Thread Starter
canderso1970's Avatar
I recently purchased a set of the newer style factory color matched lower fairings for my 2016 Road Glide Special. I also purchased OEM speaker pods to install a pair of Polk MM651 speakers. There were no baffles provided with the speaker pods. It seems to me that there should be something behind the speaker. Or am I thinking about this wrong? As of now, the speaker would just bolt into the opening and have an open cavity of air down to my feet.
Any info would be appreciated. Thanks
2016 Road Glide Special - Velocity Red
1976 Ironhead Hardtail Bobber - Citron Mist Metallic, Hand built by me
canderso1970 is offline
post #2 of 12 (permalink) Old 02-24-2016, 12:32 PM
! rock103 !'s Avatar
I would think there would be also. I'm planning on getting the Hogtunes ones to compliment the rest of the audio upgrades.
USMC 1990-2000 (0311/6017)
! rock103 ! is offline
post #3 of 12 (permalink) Old 02-24-2016, 08:38 PM
09Sharknose's Avatar
Not sure if the speaker pod changed for the 15-16 models, but I have the HD speaker pods on my 13. They fully encase the speaker. There is no opening down to the feet. The pic below is a set of hogworkz, but the HD is a similar design. ImageUploadedByMO Free1456367898.611664.jpg
09Sharknose is offline
post #4 of 12 (permalink) Old 02-25-2016, 02:42 PM
brhodea's Avatar
Speaker Pods Box Boxes 6 5" for Harley Touring Lower Vented Fairings Black HD | eBay
i Used these too, had'em painted. Didn't care for the HT because the 7.25" speakers didn't sit flush, they stuck way out and the grills would NOT hold up. The Studs the grills slid on to broke regularly, and the kept separating from the plastic.
brhodea is offline
post #5 of 12 (permalink) Old 02-25-2016, 07:59 PM Thread Starter
Here are a couple of pictures.
The newer style lower fairings:
The newer style speaker pods:
These pods are hollow and without a back. You can actually see the speaker wire hanging out of the lower fairing in the top picture. I am thinking about picking up some Dyna Mat speaker baffles. Will likely test these out without anything behind them first. Still waiting for the amp to get here anyway. That should be here tomorrow. Then I will need to run power, ground, etc.
Any suggestions on how to route the wires into the upper fairing? Is there a correct path for the wires to take from the lower fairing tot he upper fairing?
Thanks in advance.
post #6 of 12 (permalink) Old 02-25-2016, 10:56 PM
Ive seen some pods on eBay with enclosures for the new style for around $150. I just order new style lowers painted vivd black for $218
post #7 of 12 (permalink) Old 02-26-2016, 05:14 AM
brhodea's Avatar
Thanks in advance.
Those look great, My wires are run on the underside of the top of the crash bar.
brhodea is offline
post #8 of 12 (permalink) Old 02-26-2016, 10:15 AM
anonymous_1's Avatar
I've used those speaker baffles in my work car to try to contain some of the noise and to make sure they didn't get hit by water since the car is a Cracker Jack box. They seemed to work decent, they are not the cure all but I think they would defiantly help your situation. They are pretty sizable so you'll have to do some trimming, and maybe smash them in to get them to fit. But the good news is they are pretty cheap in case they don't end up working for you.
2013 Road Glide Ultra, House of Kolor custom paint, 4" Rinehart true duals, Fuel Moto AC, Power Vision, Covington covers, Biketronics 7.1" front and rear with BT4180 amp and Alpine 164bt, Hogpro 21" 6-pack
anonymous_1 is offline
post #9 of 12 (permalink) Old 03-01-2016, 03:05 PM Thread Starter
Finishing up a couple of other "needed" upgrades and then I will be getting back to the speaker and amp install.
What I have is 4 Polk MM651 speakers and a Soundstream Stealth 4 channel amp. Will I need to flash the factory head unit for this install?
I haven't read the amp install manual yet and it has been a while since I have installed sound equipment. Do I split the line out from the head unit into each line in on the amp? Any suggestions on wiring this configuration would be greatly appreciated.
Thanks in advance.
post #10 of 12 (permalink) Old 03-01-2016, 03:25 PM
Thanks in advance.
I can't speak of a flash or line leveler or nothing. I seen folks on this forum do it all 3 ways. As far as hooking up an amp by way of (high level hook up), you'll use the oem speaker wires , front/ rear, right /left, positive/negative. You run those wires into the line leveler or amp input accordingto your choice , then run the new speaker wires out of your amp. You'll also need battery power /ground, remote / switched power line . Most amps don't use a remote power line to switch the amp on/ off if your wired by way of high level . Instead, it uses the high level input that's already coming from your oem speaker wires. Follow your amps manual.
Infinity Kappas in lower fairings. (Fairing factory) 03rkjc Audio 2 01-11-2016 04:53 AM
Lower Fairing speakers or Inner Fairings speakers. Looking to "thicken" my sound a bi Tvbird Audio 14 07-24-2014 10:55 PM
Fairing Factory non-vented lower fairings mounting help BIGGRYE Paint & Bodywork Section 1 12-21-2012 06:52 PM
WTB Lower fairing top U clamps to fasten the lower fairings to the crash bar. hogger Wanted! (Buy or Trade) 12 05-20-2012 05:46 PM
Speakers for the lower fairings firecap1962 *General Road Glide Discussions/Pictures 28 12-05-2010 01:42 PM
