Bluetooth Radar Detectors and Boom Audio - Road Glide Forums
post #1 of 5 (permalink) Old 02-24-2016, 04:47 PM Thread Starter
I tend to ride relatively fast as compared to the speed limit. Like some others, I use a radar detector. Has anyone tried to connect a bluetooth radar detector to the new Boom audio systems? If so, how did it work? What equipment did you use? Were the protocals supported?
303RG is offline
post #2 of 5 (permalink) Old 02-25-2016, 12:12 AM
IdahoHacker's Avatar
Having read all the Harley literature I could find, it appears that the only Bluetooth device that will pair with the BOOM system is a smartphone.
2015 FLTRXS, SE Ventilator A/C, V&H Pro Pipe, S&S/Crane Chris Rivas Rocket 574 cams, Chris Rivas V-Twin dyno tune: 103 hp, 108 tq.
IdahoHacker is offline
post #3 of 5 (permalink) Old 02-25-2016, 07:54 AM
Smarty's Avatar
I've found the info system will find a pair with the Sena but since it will not send a signal back to it, it won't work. The radar detector, if it is compatible should be just sending a signal to the radio and would work it would seem. Interested in what you find out.
2016 RGS Black Quartz
Smarty is offline
post #4 of 5 (permalink) Old 02-25-2016, 11:15 AM Thread Starter
I guess I going to have to buy another radar detector.
303RG is offline
post #5 of 5 (permalink) Old 06-17-2016, 11:27 AM
Escort Max 2 Radar detector
I purchased an Escort Max2 detector which I was told would pair with my iPhone which is paired with my boom box. The pairings are in place, but my Boom Box is not getting the signal.
Anyone have any suggestions?
Radar Detectors-Some new Info BillyBob Aftermarket Accessories 127 01-24-2019 07:26 PM
Radar Detectors?? Nevadasun *General Road Glide Discussions/Pictures 3 05-22-2014 11:31 PM
radar detectors jaysrgu General Off-Topic Discussions 14 12-30-2013 07:36 PM
How to send sound from HK radio using Bluetooth to my Bluetooth helmut? bear25314 *General Road Glide Discussions/Pictures 2 08-16-2013 01:29 AM
