4 ohm?? - Road Glide Forums
 15Likes
post #1 of 54 (permalink) Old 02-27-2016, 09:52 AM Thread Starter
! rock103 !'s Avatar
4 ohm??
Can I run 4 ohm speakers as replacements? What are the drawbacks if any. Not an audio wiz, excuse my ignorance
USMC 1990-2000 (0311/6017)
! rock103 ! is offline
post #2 of 54 (permalink) Old 02-27-2016, 09:57 AM
Spazz's Avatar
Your 15RGS has a 2 ohm speakers. Just adding 4ohm speakers will cut your volume in half since they are double the resistance. What is your ultimate goal and how deep are you pockets? You can get a pretty decent upgrade on a fairly small budget to include speakers and an amp to drive them.
A GOOD budget speaker is the Infinity Kappa 62.11i's. They are 2 ohm and can handle a decent amp and won't break the bank.
RENO BAGGER AUDIO
Spazz is online now
post #3 of 54 (permalink) Old 02-27-2016, 10:00 AM Thread Starter
Well, thought of going with the Hogtunes setup, but been hearing alot of bad stuff about them. And how bass is really lacking. So I was looking into Kicker or Infinity. But alot of the Kicker stuff is 4ohm. I don't wanna spend a ton. Think I've decided to just put a quality 4 channel amp, upper and lower fairing speakers instead of the additional speaker lids. Since I just ordered some lowers
post #4 of 54 (permalink) Old 02-27-2016, 10:08 AM
Spazz's Avatar
I am not going to tell you where to go, but there are VERY DECENT setups out there for $500... plug and play.. speaking of 2 speakers and an amp. If you are sold on piecing together your own system, it can get nerve-racking...I said CAN. You have to deal with connections and wiring... etc....
there are good threads out there with lots of info on audio upgrades.. from budget builds to high-end. I would do some research on systems that will fit your budget... don't 'settle' if you can help it.
RENO BAGGER AUDIO
Spazz is online now
post #5 of 54 (permalink) Old 02-27-2016, 10:09 AM
twistr's Avatar
There are a lot of options if you want to piece together a system or purchase a pre-packaged system...if it were me I would look at the others before considering Hogtunes.
As other have said...using 4 ohm speakers will cut the power in half.
Riding Life's Twisting Roads...
On a 2008 Dark Blue Pearl Road Glide
twistr is offline
post #6 of 54 (permalink) Old 02-27-2016, 10:10 AM Thread Starter
Sent an email to Soundz to see what his cost would be. But thinking it's gonna be pricey. Basically I want the best "bass for the buck", and of course increased volume
post #7 of 54 (permalink) Old 02-27-2016, 10:11 AM
Rock, head over to hdforums & read up on the audio system section over there to find options for a budget system. The guys there will steer you right & you'll be able to put together something that is so much better than stock
Shadowbennie is offline
post #8 of 54 (permalink) Old 02-27-2016, 10:11 AM Thread Starter
That's what I've been hearing and am doing. Their system seems easy to installed and priced ok. But heard some issues that have me searching for a better solution
post #9 of 54 (permalink) Old 02-27-2016, 10:12 AM
Spazz's Avatar
You can do soooo much better than HT.....
RENO BAGGER AUDIO
Spazz is online now
post #10 of 54 (permalink) Old 02-27-2016, 10:15 AM Thread Starter
Been poking around there too. Been hearing great things from Soundz Customz. So gave them a shout. I want a plug and play system that is complete, since I'm not looking to have a "custom" system and want it easy for me to do myself.
Paralleling speakers 4 ohm 2 ohm using amp set up to parrallel Heavy Metal Audio 16 01-06-2018 06:09 PM
Speaker question 2 OHM or 4 OHM Ginee13 Audio 3 09-22-2015 05:53 AM
switching from 4 ohm to 2 ohm at a later date chevjerico Audio 3 05-15-2014 01:24 PM
4 ohm and 2 ohm speakers yamahoe72 Audio 7 04-13-2013 07:55 PM
