AM/FM radio problem - Road Glide Forums
 4Likes
post #1 of 12 (permalink) Old 02-28-2016, 03:08 AM Thread Starter
Rottweiler's Avatar
AM/FM radio problem
I purchased a 2009 Road Glide. The previous owner upgraded just about everything including having a Hawg Wired system put in. The speaker select switch no longer does anything. A powered antenna was also installed.
The problem I am having is everything works fine except the AM/FM radio. It's a stock Harley radio. The CD and AUX works fine when the bike is on. The AM/FM radio is just static. When I turn the ignition to ACC, the AM/FM radio works???? It's all fine and good except I can't really ride down the road with the ignition in ACC.
As far as I can tell, the main radio harness was not cut.
Any ideas??????
Rottweiler is offline
post #2 of 12 (permalink) Old 02-28-2016, 04:14 AM
RGKen's Avatar
Are the headlights HID's by chance? HID's are known for radio interference but if it's not that look for another source of electrical interference. I would say that the antenna was not hooked up properly but since you said it works on ACC it may not be that.
Big_gary likes this.
2018 FLTRXS
RGKen is online now
post #3 of 12 (permalink) Old 02-28-2016, 05:53 AM
teejay's Avatar
Is there any chance that the powered antenna is only getting power with the switch in the ACC position?
tom
teejay is offline
post #4 of 12 (permalink) Old 02-28-2016, 07:09 AM
Are all your accessory switches on? I have seen people use one of those switches for an amp or antennae?
thealien is offline
post #5 of 12 (permalink) Old 02-28-2016, 08:01 AM
I have the exact same issue. I have the LED headlights that drop in place of the old bulbs. They have fans driving to cool things down. I am thinking the two might be related but so far nothing found. HD just rubs their chins and say HUM???. I'll be watching this thread closely in case a solution is found. Headlights come on in "Ignition" position, but are off in "Access" position. Was thinking of pulling the Headlight fuse and see if the radio changes any
Big_gary and Tailbreaker like this.
Diverrick is offline
post #6 of 12 (permalink) Old 02-28-2016, 10:46 AM Thread Starter
Rottweiler's Avatar
Am/fm
Yes, I have the upgraded lights as well. On a hunch, I pulled the headlight fuse and **boom**, it works as advertised. I see the ballast for the lights is a small unit they mounted on either side of the radio. I'm going to try re-locating them to see what happens...
RGKen likes this.
post #7 of 12 (permalink) Old 02-28-2016, 06:59 PM Thread Starter
Rottweiler's Avatar
Am/fm
Ok...if I pull the headlight fuse, the radio works. If I put the fuse back in and move all the headlight related stuff, the radio does not work on either run or acc???
If I put all the light stuff back, I get radio back only in the acc position again.
Also, if I turn off the radio, as soon as I turn to run, i get static and a faint beep beep beep beep sound over the speakers, on acc, only quiet static???
Dear God.....shoot me now...
post #8 of 12 (permalink) Old 03-06-2016, 10:21 AM
madmat's Avatar
subscribed
18 RGS Bonneville Salt Pearl
madmat is online now
post #9 of 12 (permalink) Old 01-24-2017, 12:00 PM Thread Starter
Rottweiler's Avatar
I give...
So......I went all last season without using my radio. I have my scoot ripped apart for the winter and tackled this again.
I took apart the entire front end and stretched out ALL the headlight wires, components etc. With all the headlight crap 4 feet out in front of the bike, and the headlight system not grounded, radio works fine. As soon as I attach the grounds, even using a separate wire away from the bike all the way back to the neg on the battery, the radio goes all static...
The only wire/wires running anywhere near the stereo system is the power. I am wondering if shielded power wires are the answer????
I guess it's another season of iPod.....
post #10 of 12 (permalink) Old 01-24-2017, 01:12 PM
WTFranz's Avatar
Might check at a vehicle radio install place. There are several isolation products that are cheap and work if you know what to use. I had a similar problem with my boat and less than $50 later I had an isolation transformer and a coil suppressor that solved all my issues. What they technically do I have no idea, but the tunes now flow so life is good.
WTFranz is offline
Radio always starts on AM, or FM adown Audio 4 04-06-2014 09:57 AM
Harmon Kardon CD,AM/FM RADIO/ RCX pipes pat123 Parts for Sale 10 04-25-2013 07:56 PM
'04 AM/FM/CD/WB Radio w/mp3 input NFDLtE3 Sold 3 02-08-2012 11:37 AM
04 Harley cd/fm/am/weather for sale. schnid72 Audio 0 03-16-2011 10:20 PM
AM FM Antenna for 2006 Road Glide. kimmer127 Aftermarket Accessories 1 07-17-2010 10:04 AM
