2016 FLTRXS with ArcAudio MPAC6 - Road Glide Forums
post #1 of 5 (permalink) Old 02-29-2016, 12:34 PM Thread Starter
Khaotic's Avatar
I moved my MPAC 6 from my street glide to road glide. I had the HU flased by dealer for flat output. The sound is clear but playing my same iPOD doesn't seem as loud. I can however max the volume without any distortion. What I didn't do was any gain adjustment. Do others agree that with the different HU and flat flash I might gain more volume from a gain adjustment?
2016 FLTRXS 120ST, SE Elite Heavy Breather, D&D Boss Boarzilla, Bandit Sportsman Clutch, Factory47 16" Malo and Arc Audio MPAC 6.
Khaotic is offline
post #2 of 5 (permalink) Old 02-29-2016, 01:51 PM
! rock103 !'s Avatar
Here's a resource I learned from about gain settings...
Amplifier Gain Controls
USMC 1990-2000 (0311/6017)
! rock103 ! is offline
post #3 of 5 (permalink) Old 02-29-2016, 04:06 PM Thread Starter
Khaotic's Avatar
I just spoke to Brad at Arc Audio, he said I could definitely up my gains because of different HU and flat output of the flash of 1 amp 4 speakers recommended by them and also Rockford Fosgate in this doc 2014+ Harley-Davidson Equalizer Reset - Installation Advisory.
Khaotic is offline
post #4 of 5 (permalink) Old 02-29-2016, 04:59 PM
Sweet! Best advice you can get is from the manufacturer. Might have to give them a call about their Road Glide system...
post #5 of 5 (permalink) Old 03-01-2016, 06:14 AM
The Rushmore head units have a weird EQ curve designed for the Boom crap, when you put a good amp to it you get distortion when setup to the correct gains ie using a multi meter or oscilloscope.
You need a way to clean up the signal before it hits the amp to be amplified.
One of the most cost effective ways is the Biketronics Line Leveler (BT355), it has gain adjustments and HPF built in to it. I have mine set at about 2.0 out before the amp and it's can scream with those 602's.
https://www.youtube.com/watch?v=LM1U_5hkRx8
I also have a couple videos of the voltage output from the BT355's, I've gone from stock seting to max to where it is now at 2.0 volts.
Bunker is offline
2016 fltrxs rgervasijr New Members Welcome Area 14 05-10-2018 09:42 PM
fltrxs 2016 maggy Dyno Results 1 11-19-2016 06:51 AM
2016 FLTRXS 1000Mi Review motodrummer *General Road Glide Discussions/Pictures 12 08-31-2016 03:15 AM
Instruments dead in 2016 FLTRXS scopet563 Troubleshooting for Road Glides 4 07-15-2016 08:51 AM
2016 FLTRXS first impressions thealien *General Road Glide Discussions/Pictures 5 03-11-2016 11:06 AM
