Battery Draining after stereo/amp install - Road Glide Forums
post #1 of 9 (permalink) Old 03-02-2016, 12:24 PM Thread Starter
Ok so i installed a new sony head unit and kenwood amp i used the Metra install kit which is all plug and play. I ran the power from the amp strait to the battery and the amp ground with the head unit ground something is still drawing power causeing the battery to be dead over night...Can anyone here help me trouble shoot this issue.
soup22 is offline
post #2 of 9 (permalink) Old 03-02-2016, 01:22 PM
wevsspot's Avatar
Hey Soup, knowing exact model numbers of the head unit and the AMP would be helpful.
Just stabbing in the dark I'd say that your AMP isn't powering down when the bike is off.
wevsspot is offline
post #3 of 9 (permalink) Old 03-02-2016, 02:45 PM
did you hookup the remote wire to key on power feed?
Bunker is offline
post #4 of 9 (permalink) Old 03-02-2016, 02:50 PM
VikingRider's Avatar
Hi soup22; I second what wevsspot said.
Bear with me I just have to ask – does your head-unit come with a remote turn-on wire? If not, you need to wire the remote turn-on from the amp to the power wire of the head-unit. You could also use a power wire from the acc which turn off with the ignition.
Just for the record – I have learnt everything the hard way!
FLTRSEI2
VikingRider is offline
post #5 of 9 (permalink) Old 03-02-2016, 03:08 PM
Like other 2 guys said, remote turn on wire
phillyfan1 is offline
post #6 of 9 (permalink) Old 03-02-2016, 03:49 PM
I thought I was reading something over on HDF about some guys having trouble with the metra kits draining their battery. May want to pop over there and do a search to see what you can find.
Easy way to test this is to disconnect the metra overnight tonight to see if it still happens.....
Shadowbennie is offline
post #7 of 9 (permalink) Old 03-02-2016, 03:52 PM
Smarty's Avatar
Just pull the inline fuse you put on the feed wire and leave til overnight for check.
2016 RGS Black Quartz
Smarty is offline
post #8 of 9 (permalink) Old 03-03-2016, 08:54 AM Thread Starter
well after talking to Metra when i installed the kit and turned the bike on to check it i didnt hook up the blinkers which has caused the system to stay on. They said it has something to do with the bike computer going into safe mode. I have to uninstall the kit and reinstall the factory stereo turn it on with all lights reconected then turn it off let it sit for 5 min then uninstall the factory stereo and re install the after market stuff. THEN put everything back together before turning the key on....more troublr than it worth lol
soup22 is offline
post #9 of 9 (permalink) Old 03-03-2016, 09:59 AM
What bike you working on ?
Big_gary is online now
2015 road glide draining battery with key off? Merlinwag *General Road Glide Discussions/Pictures 0 05-16-2016 10:30 AM
Draining fuel dietz Do-IT-Yourself 9 03-29-2016 04:47 AM
Battery Draining 09Sharknose Audio 3 08-13-2015 08:11 AM
Stereo issues after amp install HDRG13 Audio 28 12-22-2014 10:08 PM
Battery dead after amp install infernomd Audio 12 09-04-2013 02:08 PM
