Cerwin Vega amp help. - Road Glide Forums
 8Likes
post #1 of 20 (permalink) Old 03-07-2016, 12:48 PM Thread Starter
BigNorm's Avatar
I'm looking into getting the cerwin vega bomber amp. What else do I need to hook it to the stock stereo? I'm not sure what hardware comes with it.
BigNorm is offline
post #2 of 20 (permalink) Old 03-07-2016, 01:45 PM
wevsspot's Avatar
Hey Norm. To use one of CV's Stealth Bomber AMPs you'll need;
1. 8 or 10 gauge positive wire for running power from battery to AMP
2. In line fuse for power wire from battery to AMP (40A to 50A)
3. 8 or 10 gauge negative wire for ground. Termination point of this ground wire has been debated ranging from connecting to the frame fairing mount, directly to the negative lead of the battery or the whole system common ground point near the battery. On mine I terminated the ground wire at the whole system common ground point near the battery.
4. 18 to 20 gauge remote turn on wire
5. Line out converter (converts the high level speaker outputs from the head unit to RCA low level inputs for the AMP) I recommend the Biketronics BT355 if you can swing it.
6. 2-4' RCA cable for connecting line out converter to the AMP
7. Some extra speaker wire to go from AMP to speakers
Not sure if you're replacing speakers as well, but if so you may need compatible terminals so you can connect your speaker wires to the speakers. The Harley terminals are designed specifically for the Harley speakers.
Depending on how (or if) you plan to do any splicing you'll need some type of crimp terminals or a solder iron and heat shrink tubing.
If you are going to connect your remote turn on wire to another switch powered wire (the cigarette lighter for example) you'll need a t-type terminal or some other method of joining the wires.
There are some suppliers who offer complete AMP install wiring kits and depending on which one you get they are only marginally more expensive than buying the parts and pieces individually.
Since I like doing my own thing I purchased all of the parts and pieces individually.
wevsspot is offline
post #3 of 20 (permalink) Old 03-07-2016, 03:10 PM Thread Starter
BigNorm's Avatar
That's a list of hardware. Thanks for taking the time to share it. My passion is the motor and moving parts but I do like my tunes. I'm on my second set of stock speakers. lol.
BigNorm is offline
post #4 of 20 (permalink) Old 03-07-2016, 04:20 PM Thread Starter
BigNorm's Avatar
Is there a line out adapter that will work that doesn't cost $75?
BigNorm is offline
post #5 of 20 (permalink) Old 03-07-2016, 04:36 PM Thread Starter
BigNorm's Avatar
will I need two line out adapters if I have rear speakers as well? I'm just wondering about the fader. Thanks.
BigNorm is offline
post #6 of 20 (permalink) Old 03-07-2016, 04:54 PM
EvilTwinATX's Avatar
You will need two line out adapters if you want to use the fader option. or you can tune the amp and use y-rca splitters to split the signal. You dont need the fader then.
You will have to get the bike flashed to enable the fader option at the dealer.
EvilTwinATX is offline
post #7 of 20 (permalink) Old 03-08-2016, 07:03 AM Thread Starter
BigNorm's Avatar
I noticed that that line out adapter he recommended was for a '15up so you didn't need the reflash. Mine is a 2011. I am totally new to playing with the stereo on this.
BigNorm is offline
post #8 of 20 (permalink) Old 03-08-2016, 08:00 AM
You need a PAC SNI-35 converter.
N2DEEP is offline
post #9 of 20 (permalink) Old 03-08-2016, 10:12 AM
wevsspot's Avatar
Yep, the PAC SNI-35 will work as well. So will the PAC SNI-15 and if you can't find either of those local you can hit up a local Best Buy (if you have one) and pick up one of their Metra TC-LOC2 for about $15 bucks. I've personally used all four now in search of the "perfect" solution.
Finally settled on the BT355 because I'm on a 2015 bike with terrible EQ when the bike is running. However, in truth the CV Bomber series do have a variable HPF adjustment so you can achieve almost the same results as the BT355.
N2DEEP likes this.
wevsspot is offline
post #10 of 20 (permalink) Old 03-08-2016, 11:11 AM Thread Starter
BigNorm's Avatar
Thanks. Will I still need to get the radio flashed if I install an amp?
BigNorm is offline
What looks like B52 Cerwin Vega Amp paralleled Heavy Metal Audio 0 03-06-2018 09:54 AM
Cerwin Vega Jfmjr Audio 4 04-27-2017 01:54 PM
Cerwin vega B52? Redrock Audio 16 03-21-2017 09:24 PM
Cerwin Vega B4 Amp Settings? StalkR Audio 0 03-20-2016 01:50 PM
Cerwin vega amp Bubba Audio 10 02-02-2012 09:37 PM
