speakers Need air - Road Glide Forums
post #1 of 11 (permalink) Old 03-16-2016, 05:47 AM Thread Starter
speakers Need air
Is it a good idea too seal up these road glide pods? Seams To me if you are running a big mag.speaker with big power you should use more air.
dozer23 is offline
post #2 of 11 (permalink) Old 03-16-2016, 05:58 AM
You seal them up so that you don't hear any whistling with a high power system. It will suck air through the seems if their not sealed up.
Bunker is offline
post #3 of 11 (permalink) Old 03-16-2016, 06:26 AM Thread Starter
Ok so wear will the speaker get air from If the pod is sealed? I was about to seal the pods and said I better ask the ?
dozer23 is offline
post #4 of 11 (permalink) Old 03-16-2016, 06:55 AM
Khaotic's Avatar
speakers Need air
All references on web to sealed or ported speaker enclosures reference woofers. Its more about buzzing through crack. i guess you could also drill a true port hole and test for performance and plug hole if it sounds worse.
http://ridebass.com/ported-vs-sealed-car-subwoofer-box/
2016 FLTRXS 120ST, SE Elite Heavy Breather, D&D Boss Boarzilla, Bandit Sportsman Clutch, Factory47 16" Malo and Arc Audio MPAC 6.
Khaotic is offline
post #5 of 11 (permalink) Old 03-16-2016, 09:32 AM
! rock103 !'s Avatar
Ported VS Sealed Subwoofer : Which Is Really Better ? | RideBass
Great info
USMC 1990-2000 (0311/6017)
! rock103 ! is offline
post #6 of 11 (permalink) Old 03-16-2016, 06:16 PM
you'll notice when you take the pod out there is a "drain" hole at the bottom. I left that open and sealed the seam all the rest of the way around the pod. No whistling through any cracks.
Bunker is offline
post #7 of 11 (permalink) Old 03-16-2016, 06:37 PM
tdkkart's Avatar
The CVOs have the rear speaker pods vented to the tourpak with approx. 2" holes. Supposed to increase the base.
tdkkart is offline
post #8 of 11 (permalink) Old 03-20-2016, 08:23 AM
RichardTL's Avatar
Ported speakers give you deep bass sound with some reverb at high volume. Sealed speakers give a tight, crisp sound. The "benefit" of a sealed speaker is as the speaker drives the bass note, it creates a vacuum to pull the speaker back. The vacuum, in conjunction with the change in polarity at the voice coil, makes for a quick, tight transition between frequencies. The "drawback" of a sealed enclosure is the cone doesn't have as much throw to reach deeper notes because of the vacuum.
By comparison, if you want to hear the deeper notes, a ported speaker allows the cone to move more freely (longer throw for lower frequencies) but at higher volumes you lose some clarity. A ported enclosure doesn't need as much volume to hit lower notes.
There still limitations regardless if you use a sealed or ported speaker--the smaller the cone, the less bass you'll hear. A 6" cone won't sound as "deep" as an 8" cone only because of the amount of air being moved.
RichardTL is offline
post #9 of 11 (permalink) Old 03-20-2016, 09:30 AM
RICKLB58's Avatar
Harley sells a kit to port the pods into the tourpack for those that don't already have them ported. A little pricey but what HD part isn't.
2012 RGU, Thunder Max tuner, V/H power duals, Stage one, DayMakers, 12 inch F47 Malos, custom gages, and some extra chrome.
RICKLB58 is offline
post #10 of 11 (permalink) Old 03-21-2016, 11:33 PM
beatlesfab4fan's Avatar
I am getting ready to pull the fairing on mine and I have a question.
Is the pod a 2 piece and if so do you split the pod, run a bead of silicone and then put the 2 pieces back together or just run a bead around the seam?
What is best and does anyone have pics, which would be helpful.
TIA,
Mike
beatlesfab4fan is offline
WTB: Hogtunes 24.2 amp and 5x7 speakers - or other speakers w/ rings kyle31490 Wanted! (Buy or Trade) 5 06-16-2015 02:33 PM
Lower Fairing speakers or Inner Fairings speakers. Looking to "thicken" my sound a bi Tvbird Audio 14 07-24-2014 10:55 PM
inner fairing depth for speakers & Critical Mass speakers vinman4444 Audio 9 01-06-2014 06:58 PM
2 speakers or 4 speakers LeotheThird Audio 9 04-13-2013 10:15 PM
After you install J&M or other speakers, what do you do with the factory speakers? Black09inOK Do-IT-Yourself 6 10-01-2010 01:53 AM
