wiring lower speakers? - Road Glide Forums
post #1 of 3 (permalink) Old 12-07-2012, 11:10 PM Thread Starter
gsbuick65's Avatar
putting the cvo lowers on my ultra, I have a alpine ktp445u 4 channel amp. My question is how do I wire the amp to the front 4 speakers? can I tie the 2 set of wires from the stereo to the 4 set of the input of the amp?
Mike Southaven Ms. 2011 RGU merlot, Rinehart true duals, s&s 570 cams, Power Vision stage 1 a/c, Madstad shield, J&M 7 1/4's, Alpine KTP445U amp, CVO lowers.
gsbuick65 is offline
post #2 of 3 (permalink) Old 12-14-2012, 07:07 AM
I dont know if you got the answer yet but I tried to do this on my bike and it made the speakers crack. I have 2 1600 watt 4 channel amps and wanted too have everything wired for future updates. I tried to wire 2 high level outputs into 4 high level inputs. Sounded awesome until about 1/2 volume then the speakers would make a cracking sound. I can also tell you that the amp you are using is NOT 2 Ohm stable. Hope this helps!!
cranecaresam is offline
post #3 of 3 (permalink) Old 12-14-2012, 08:15 AM Thread Starter
gsbuick65's Avatar
Question
Yea got it wired up, called alpine they said to tie the 2 coming from the radio to the 4 input of amp. But I still can't adjust the gain, the amp is stable @ 2 or 4 ohms, found it in the manual.
Add lower speakers or Tourpak speakers? dawgcasa Audio 13 03-25-2017 09:03 AM
Lower Fairing speakers or Inner Fairings speakers. Looking to "thicken" my sound a bi Tvbird Audio 14 07-24-2014 10:55 PM
If I lower the rear do I have to lower the front?? StrokerAce Suspensions 13 11-17-2013 01:32 PM
WTB Lower fairing top U clamps to fasten the lower fairings to the crash bar. hogger Wanted! (Buy or Trade) 12 05-20-2012 05:46 PM
Help with wiring 6 speakers system. riccardo_21 Audio 2 05-27-2011 10:23 AM
