Antenna Thread Size - Road Glide Forums
post #1 of 6 (permalink) Old 04-11-2016, 06:52 PM Thread Starter
lil chief's Avatar
Antenna Thread Size
Anyone know what size the threaded antenna stud is on a '15 RG? I'm assuming it's a 10mm, but I wanted to be sure. I want to purchase a little stubby antenna due to the tour pak being just above it, & I'm not interested in the antenna relocation kit. I'm not worried about reception, because I hardly every use the fm/weather band functions. I just want a shorter antenna is all.
Thanks,
Lil Chief
lil chief is offline
post #2 of 6 (permalink) Old 04-11-2016, 07:26 PM
RoadGlideGary's Avatar
Not sure what the size is but I did the same conversion - the new antenna came with several adapters of different thread. You could take the stock off and go to the local hardware store and check the thread size?
05' SuperGlideCustom - sold
RoadGlideGary is offline
post #3 of 6 (permalink) Old 04-11-2016, 07:30 PM Thread Starter
lil chief's Avatar
Thanks man. I think I've got some assorted metric nuts around here which I can check to see if they thread on the stud.
Lil Chief
post #4 of 6 (permalink) Old 04-11-2016, 07:43 PM
I've tried a couple of the shorter antennas and was not happy with the reception. I also don't like the relocation setup. I tried the stock antenna hidden behind the shock and up under the seat. The stock antenna wire was piano tight and I didn't like it. I bought the longer antenna cable from the relocation kit and am going to try the stock antenna trick again with the longer cable?
thealien is offline
post #5 of 6 (permalink) Old 04-11-2016, 08:11 PM Thread Starter
lil chief's Avatar
I've got a 9" rubber antenna on there now that I had laying around. It actually has pretty good reception, but it's curved under the bottom of the tour pak because it's too long. I don't really care about the reception, since I don't listen to too much FM or AM at all on the bike.
Lil' Chief
post #6 of 6 (permalink) Old 04-15-2016, 06:55 PM Thread Starter
lil chief's Avatar
Got it figured out.
It's a 6mm x 24
Lil Chief
Hidden Antenna? Wes10RG Aftermarket Accessories 11 10-25-2017 10:00 AM
Remove Rear Antenna- Add Hidden Antenna- Hurt Reception? scottrgs Audio 4 09-06-2017 10:34 AM
Another Hidden Antenna Thread cleanrider Audio 11 03-06-2012 03:28 PM
2010 King Tour Pack with hidden antenna in Fairing DED HD Aftermarket Accessories 0 07-26-2010 01:34 PM
AM FM Antenna for 2006 Road Glide. kimmer127 Aftermarket Accessories 1 07-17-2010 10:04 AM
