speaker wire code - Road Glide Forums
post #1 of 7 (permalink) Old 12-10-2012, 09:28 PM Thread Starter
gsbuick65's Avatar
speaker wire code
anybody know the wire colors for the front speakers on my RGU? I cut the ends off when I put in the J&Ms so dont know which one is +&- to wire the amp. or how to figure it out with a ohmmeter.
Mike Southaven Ms. 2011 RGU merlot, Rinehart true duals, s&s 570 cams, Power Vision stage 1 a/c, Madstad shield, J&M 7 1/4's, Alpine KTP445U amp, CVO lowers.
gsbuick65 is offline
post #2 of 7 (permalink) Old 12-11-2012, 04:18 AM
h-donut's Avatar
usually the wire with a stripe is negative
or the wire with highest voltage of the pair, positve
sometimes I have to read "multi meter instuctions" right before using it
manual
http://manuals.harborfreight.com/man...2999/92020.pdf
test leads
http://www.harborfreight.com/18-inch...ads-66717.html
2010 FLTRX- r o a d g l i d e
h-donut is offline
post #3 of 7 (permalink) Old 12-11-2012, 08:19 AM Thread Starter
gsbuick65's Avatar
manual
test leads
The're all 4 striped, just different colors, none black.
post #4 of 7 (permalink) Old 12-11-2012, 09:48 AM
h-donut's Avatar
from a previous post on the subject
Originally Posted by Wildman View Post
Gray is + and Green is - hope this helps. Mine is a 2011 FLTRU but they should be the same.
h-donut is offline
post #5 of 7 (permalink) Old 12-11-2012, 09:54 AM
Why did you cut the wires? I have J&M speakers and they came with everything needed to plug and play no cutting of wire needed.
Left front + wire is white and orange
left front - wire is light green and white
right front + wire is gray and red
right front - wire is light green and black
Hope this helps you out.
post #6 of 7 (permalink) Old 12-11-2012, 07:41 PM Thread Starter
gsbuick65's Avatar
I ran the thru my amp, wanta make sure I hooked it up right.
thats what I needed, knew which was left and right, just not +&-, thanks
post #7 of 7 (permalink) Old 12-11-2012, 07:47 PM
No problem hope you get thing working.
B 54 speaker wire color code bigal51 Audio 4 03-19-2018 09:03 PM
Lower Fairing Speaker pods: How did you guys run the speaker wire? Slider57 Audio 3 02-10-2018 03:12 PM
16 RGS rear speaker harness color code HD2fly Audio 3 07-18-2017 07:05 AM
Error code question or at least I think it's an error code wvdave Troubleshooting for Road Glides 1 07-15-2015 10:21 AM
Sadelbag speaker wire quick disconect? Mopar1 Audio 6 03-05-2012 10:31 PM
