Need advice on 4 in the Fairing install - Road Glide Forums
post #1 of 4 (permalink) Old 12-12-2012, 08:01 AM Thread Starter
I have my inner fairing off and ready to go to the painter this weekend and I need to make the holes for the speakers that are facing the Forks. I think I remember a install tread but the search option is not working with my phone.
What size hole saw for 6 1/2 speakers?
How do you locate where the hole will go? Measurements or wing it?
What is the max mounting depth?
Should I go with a PBR300x2 with 2 speakers per channel or PBR300x4? Speakers are a older set of Focal 165 with a rating of 60watts rms and 120 peak @ 4 ohms
Thanks Jim
Jims79FLH is offline
post #2 of 4 (permalink) Old 12-12-2012, 08:40 AM
I personally like the PBR 300x2 better, and I have both amps. If you send me a PM with your e-mail I can send you more info on the install. If you have the speakers you are going to use they are the best template.
dbell66253 is online now
post #3 of 4 (permalink) Old 12-12-2012, 10:30 AM Thread Starter
PM sent..............
post #4 of 4 (permalink) Old 12-12-2012, 12:15 PM
PM and email sent....
Daymaker install advice Lucky D Lighting 21 01-25-2014 10:51 PM
Vance & Hines Power Duals install - could need your help / advice J-J,DE Intake and Exhaust 22 05-08-2013 07:17 AM
Daymaker Install Advice Clarification Lucky D Lighting 4 03-12-2013 09:16 AM
Need help---RGU fairing install issue craigp95 Controls & Handlebars 9 04-28-2012 12:42 PM
Mentra Antenna Install Advice bbass Audio 4 08-08-2011 09:57 AM
