Question on 4 speakers within inner fairing - Road Glide Forums
post #1 of 12 (permalink) Old 12-15-2012, 09:55 AM Thread Starter
I'm just starting to look for speakers and I'm not sure what is the maximum mounted depth I can go to for the upper and lower speakers. For the lowers, I don't want to cut into the glove boxes.
I have 2 RF 300X4 and a JVC Arsenal KD-A95BT waiting for speakers.
I'm looking at focal 6.5" components (upper & replace 2 gauges) and CDT 6.5" woofers on the inside/lower.
So far I've seen speakers with a mounting depth of 1.9" to right at 3"
Any help would be greatly appreciated.
2016 CVO Road Glide
SMSgt B is offline
post #2 of 12 (permalink) Old 12-15-2012, 05:05 PM
I used the same RF speakers Yaffe uses in their house party system, I also did the cut with the inner fairing still mounted to the bike. I guess you could go to the RF sight to get the dimensions. BTW have you thought about either mounting the tweeters or buying a grill with tweeters instead of getting rid of guages?
post #3 of 12 (permalink) Old 12-15-2012, 05:25 PM
This is how I put in my tweeters...... no loss of gauges
2011 Sedona Orange FLTRX, 124" S&S, D&D Boarzilla, 66mm Thottle Hog, Streched and Custom
piesik650 is offline
post #4 of 12 (permalink) Old 12-15-2012, 06:58 PM
That's a good place for the tweeters, how do they sound?
post #5 of 12 (permalink) Old 12-15-2012, 07:20 PM
Sound great those tweeters are actually the mates for my lowers speakers. The really come alive at high volume at high speeds
post #6 of 12 (permalink) Old 12-15-2012, 09:01 PM Thread Starter
I planned on removing the air temp and fuel for tweeters, but this idea might change my mind. Man that looks great. I have a set of gauge mounting CVO tweeters I was going to for the mounting hardware.
2016 CVO Road Glide
SMSgt B is offline
post #7 of 12 (permalink) Old 12-15-2012, 09:17 PM
It's a little scary drlling big holes in you fairing. but the pay off was great.
post #8 of 12 (permalink) Old 12-18-2012, 08:19 AM
tkbalt's Avatar
I have 2 sets of JL Audio ZR650 Component speakers in my fairing. One set of tweeters are hidden behind the speaker grills along with the upper speakers - the other set are mounted in the lower fairing similar to piesik650's. My glove boxes were modified. Pics are in this thread:
https://www.roadglide.org/showthread.php?t=12868&page=7
tkbalt is offline
post #9 of 12 (permalink) Old 12-18-2012, 08:25 AM
Q-Hog's Avatar
As for your tweeters, you can find a 1"-2" set & mount (drill hole) it in the corners of the stock inner fairing speaker housing. That's what I did. You might have to enlarge the pic to see the extra tweeter on the right side.
Q-Hog is offline
post #10 of 12 (permalink) Old 12-18-2012, 07:38 PM Thread Starter
Attachment 17755
That right there is the way I will go ... no loss of gauge or another visible hole in the fairing. Thanks for the info.
2016 CVO Road Glide
SMSgt B is offline
Lower Fairing speakers or Inner Fairings speakers. Looking to "thicken" my sound a bi Tvbird Audio 14 07-24-2014 10:55 PM
inner fairing depth for speakers & Critical Mass speakers vinman4444 Audio 9 01-06-2014 06:58 PM
Buying within 45 Days - How much at the Dealer? Ophir *General Road Glide Discussions/Pictures 31 12-23-2012 02:16 PM
How to determine the revision of the map within the ECM? Wood Troubleshooting for Road Glides 2 07-12-2012 08:09 AM
