Correct way to wire 4 Polk Audio MM651? - Road Glide Forums
post #1 of 6 (permalink) Old 12-15-2012, 10:04 AM Thread Starter
glide1's Avatar
I want to use 4 of these speakers in the Fairing using either the PBR300X4 or 300x2. Is there a way to wire them in Series or Parallel so one of these amps could be used? There 2.7 ohms each so which amp would give each of them the most wattage? The PBR300X4 is 75w per channel 4ohm stable only, While the PBR300X2 goes down to 2ohm. Can someone please explain to me the right way to wire these puppys if its even possible, So I wont burn anything,,,Pictures would really help..
glide1 is offline
post #2 of 6 (permalink) Old 12-15-2012, 05:47 PM
h-donut's Avatar
2 sets of 4ohm speakers wired parallel to 2ohm draws the most power from the amp if the amp is 2ohm stable (PBR3002)
2 sets of 2ohm speakers wired to series draws a 4ohm load from that same amp in a more conservative fashion, should still be loud though
series is + to - between two speakers - someone on here had a real good diagram
2010 FLTRX- r o a d g l i d e
h-donut is offline
post #3 of 6 (permalink) Old 12-15-2012, 06:01 PM
RGUrider's Avatar
I've found this site helpful
http://www.bcae1.com/spkrmlti.htm
RGUrider is offline
post #4 of 6 (permalink) Old 12-15-2012, 06:50 PM
JMJOHN
JMJOHN's Avatar
this video also helps with wiring multiple speakers to an amplifer http://www.youtube.com/watch?v=NJj7CrxUTts ,,,,,
JMJOHN ----
JMJOHN is offline
post #5 of 6 (permalink) Old 12-15-2012, 10:51 PM Thread Starter
glide1's Avatar
So if I wire them in series, would that mean 300 watts in total going to all 4 speakers- 75watts for each speaker? Would that be enough to power the MM651? They are 100w a piece.
glide1 is offline
post #6 of 6 (permalink) Old 12-16-2012, 07:06 PM
h-donut's Avatar
headroom
RMS wattage is usually a range
doesn't sound like you'de be under powering them by much if run in series.
that is the reason I went with the 2 sets of 4ohm speakers run at 2ohm, very evenly matched power, bang for the buck
although I wanted the MM's more based on specs
based on the lack of complaints about the MM series I'd say they're a winner.
my polk db's even sound great with hawg wired crossovers, which was a one time accident, but it tells me polks are deficient to some degree in that area, but otherwise great speakers
it might take a while deciding what works and how it will go.
I set up a working bench lab, at one point to try different stuff, and take
measurements, never got the MM's at the time, because they were backordered and ended up with hawg wired, which are point on, needed a set of "dummy" speakers to bring down the ohm load, used pioneers, just to
cut the holes, and just left them in there.
maybe just start with one pair of MM's and go from there.
add a second amp later?
what is your setup??? or future plans
just four for now?
it's doable, you just want to make sure it's as loud and clear as possible?
h-donut is offline
Polk Audio MM651 Spazeack Audio 17 06-22-2015 07:56 PM
polk mm651 Deadstroke Audio 3 07-30-2013 10:55 AM
Polk Audio MM651 speakers yamahoe72 Sold 2 05-11-2013 12:32 PM
Polk MM651 sjspeed Audio 9 06-03-2012 11:10 PM
Blown Polk MM651- Now what? HDFFR Audio 2 05-09-2012 10:23 AM
