Speakers - Road Glide Forums
post #1 of 3 (permalink) Old 12-20-2012, 11:14 PM Thread Starter
Talking Speakers
I replaced my hog tunes frt speakers 05 Roadglide with H-D Boom and after reading the paper work it says 05 and earlier will cause component damage. Difference in speaker ohms. Should I worry.
Karlcin18 is offline
post #2 of 3 (permalink) Old 12-21-2012, 05:40 AM
The mismatched impedance between the speakers and the audio output drivers can cause premature failure of the audio output circuits.
I believe the 2005 and earlier had 8 ohm speakers and if you switched to 2 ohm, you will probably fry the output transformer. If the old system was 2ohm and you switched to 8 ohm, you would usually just have lower volume. Going 8 ohm on the output to 2 ohm is almost akin to shorting the output of the radio.
Do you have an amp? If so, is the impedance selectable (2, 4, 8?). Or,you could add an amp with that capability.
Captain13 is offline
post #3 of 3 (permalink) Old 12-23-2012, 07:53 AM Thread Starter
Thumbs up
Thanks I guess I'll send the hog tunes to be checked and hope for new then during winter work o/t and get newer system cause I only have a fltr not fltru added tour pack and will need speakers for that also. Loving the bike first H-D left the goldwing behind.
WTB: Hogtunes 24.2 amp and 5x7 speakers - or other speakers w/ rings kyle31490 Wanted! (Buy or Trade) 5 06-16-2015 02:33 PM
Lower Fairing speakers or Inner Fairings speakers. Looking to "thicken" my sound a bi Tvbird Audio 14 07-24-2014 10:55 PM
inner fairing depth for speakers & Critical Mass speakers vinman4444 Audio 9 01-06-2014 06:58 PM
2 speakers or 4 speakers LeotheThird Audio 9 04-13-2013 10:15 PM
After you install J&M or other speakers, what do you do with the factory speakers? Black09inOK Do-IT-Yourself 6 10-01-2010 01:53 AM
