bass booster port - Road Glide Forums
post #1 of 3 (permalink) Old 12-23-2012, 02:53 PM Thread Starter
Tom
bass booster port
just wondering, i'm putting in a hogtunes amp and 5x7 speakers in my
05 road glide fairing, as i understand, the bass booster port for the
tour pack speaker pod for better base sound - would the same idea work
if i drilled on the inside of the fairing facing the forks ? Thanks
Tom is offline
post #2 of 3 (permalink) Old 12-23-2012, 08:57 PM
Shrug's Avatar
Send a message via Yahoo to Shrug
I don't think you'll get nearly the same effect. In fact, it'll probably make things worse. The Tour Pak bass ports really work, but they work because they port the low frequencies into a sealed enclosure where resonance is increased. In any speaker, the enclosure is almost as important as the drivers. Higher end speaker enclosures are tuned dimensionally specifically for the size (diameter and throw) of the woofer. The inside of the road Glide fairing provides superior bass response over the bat wing primarily because of its size. Drilling holes into open air will negate any acoustic compression you might have gained from the natural cavernous size.
Shrug - Scott Wilson
2010 FLTRX "Hester 2.0" -
Shrug is offline
post #3 of 3 (permalink) Old 12-23-2012, 10:47 PM Thread Starter
Tom
thanks Shrug - makes sense - guess i'll have to put the drill down
Tom is offline
Boom Audio Bass Port Kit Wooden Nickel Audio 34 05-06-2019 02:43 PM
Compact or Micro Jump Starter/Booster Cakeman1 *General Road Glide Discussions/Pictures 30 05-03-2015 01:39 PM
BOOM! Audio Bass Booster Tour-Pak Port Kit? Lunchbox *General Road Glide Discussions/Pictures 4 10-16-2012 03:03 PM
Question about Boom Audio bass booster SurlyBoy Equipment-RG 4 09-26-2012 03:02 PM
Bass booster for tour pak port kit kclaar Audio 6 01-15-2012 04:37 PM
