Rockford amp and Focal speakers - Road Glide Forums
post #1 of 6 (permalink) Old 12-24-2012, 08:42 PM Thread Starter
I will Temporarily be running a set of used Focal speakers and was wondering if I can hook it up to a two channel amplifier on one channel only? They are rated at 60 watts rms a piece. I don't have enough cash for the Polk mm651 and a pbr300x2 that I would like to run and was hoping this would get me by for a few Months.
Jims79FLH is offline
post #2 of 6 (permalink) Old 12-24-2012, 09:31 PM
h-donut's Avatar
PBR300x2 does mono bridged
but stereo operation at 4ohm with focals should sound good
not sure if that helps
2010 FLTRX- r o a d g l i d e
h-donut is offline
post #3 of 6 (permalink) Old 12-24-2012, 10:31 PM Thread Starter
1 channel used for for both speakers and 1 channel not used at all works? I will hopefully get Polk MM651 in the next few mounts.
post #4 of 6 (permalink) Old 12-24-2012, 10:54 PM
h-donut's Avatar
it's bridged at 4ohms, so just hook it up normally in stereo
when you swap out the speakers later the amp will sense the change and run at the slightly higher power output, 2ohm automatically
h-donut is offline
post #5 of 6 (permalink) Old 12-24-2012, 11:01 PM
h-donut's Avatar
bridging doesn't seem necessary
http://rftech.custhelp.com/app/answe...dging-addendum
h-donut is offline
post #6 of 6 (permalink) Old 12-24-2012, 11:44 PM Thread Starter
That's a good link. BTW thanks for the Amp mount.
Focal speakers and tweeters hognit Audio 3 06-16-2015 07:40 AM
I added a Focal amp and speakers on my 15 RGS. Where do I get remote power? Major99 Audio 10 03-15-2015 12:50 PM
Looking into a focal amp and speakers Major99 Audio 15 12-18-2014 12:14 AM
Anyone using "Focal" component set up with Rockford Fosgate 300 amp? Valduzy Audio 2 04-04-2014 01:13 AM
Rockford Fosegate amp & speakers vaughtcity Audio 34 02-17-2012 09:17 PM
