ARC Audio amp install question - Road Glide Forums
post #1 of 15 (permalink) Old 01-11-2013, 08:30 AM Thread Starter
Shark of the Month October 13
Location: Was northern Maine, now gulf coast of Florida
This amp is a bit too large to mount on top of standard head unit (which is what I was hoping for) so how are people mounting them on their RGs? I've read that some use a heavy duty velcro and mount to the fairing itself, anyone tried that method and how did it work out? Which velcro model did you use? I travel some reasonably rough (frost heaves, etc.) roads and don't want it coming loose from being jounced around. Your thoughts, tips?
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming “Wow! What a Ride!” - HST
Uncle Fuzzy is offline
post #2 of 15 (permalink) Old 01-11-2013, 09:20 AM
RichieRich's Avatar
An audio shop here mounts them to the right inner fairing, horizontally, on a custom aluminum plate. Similiar to the way the Boom amp mounts. I've also seen them bag mounted.
2013 BBP FLTRX
RichieRich is offline
post #3 of 15 (permalink) Old 01-11-2013, 09:28 AM
laxinharley's Avatar
My buddy mounted it to the right, inside of the fairing with a combination of
3m adhesive tape and industrial velcro. He had plans to make a bracket, but a year later its still there. So he said F it. Still running it that way.
laxinharley is offline
post #4 of 15 (permalink) Old 01-11-2013, 11:17 AM
I've always mounted my amps on the side of the inner fairing using industrial strength velcro from home depot. never had them budge in over 10,000 miles. The two amps I had were the Elf (exact same as Arc, just different name) and the RF PBR300X2.
For a very small period of time I installed the plate mount which is often used and attached kind of in the front of the inner fairing. Within 3 weeks my amp blew due to water and dust while on a big bike trip. Just from my experience and my two cents, velcroing it to the side is a better solution because it is protected from water and dust better in all weather riding.
Of course mounting it on the side with velcro goes out the window if you add inner fairing speakers.
2012 FLTRX - stage 1.5 headwork, dragos 580 cams, 10.25 comp, FM stage 1 intake, dragula 2, TTS, 13" windvest, 14" evil apes, JRI 12" shocks, progressive monotubes, hertz and alpine, hawg wired amp, custom LED gauges, custom dynamics LED signals, lots o' powder coat
San Diego, CA
modot66 is offline
post #5 of 15 (permalink) Old 01-11-2013, 11:55 AM
Q-Hog's Avatar
How are good are the ARC/RF amps compared to a conventional amp w/the same specs? Just curious..
Q-Hog is offline
post #6 of 15 (permalink) Old 01-11-2013, 02:42 PM
NorCal's Avatar
here are several photos of my Arc Audio KS 125-2 BX2 amp mounted with velcro to the side of my fairing on my RGC. It has been there for 3K miles and when I had the fairing off the other day it had not budged. I did not do the install so I don't know where he bought the velcro. When I questioned the velcro he said he could mount the amp on an aluminum plate and bolt it to the inner fairing but I did not want the bolt heads visible. He said he's never had a problem with the velcroing the amp.
NorCal is offline
post #7 of 15 (permalink) Old 01-11-2013, 03:13 PM
598Malibu's Avatar
The installer did a very nice job. Very nice wiring. I've seen some stereo shops do hack jobs at times.
2012 Big Blue Pearl FLTRU
72 Chevelle with Procharged 598
598Malibu is offline
post #8 of 15 (permalink) Old 01-11-2013, 03:49 PM
Very clean job. Who did the work?
Jims79FLH is offline
post #9 of 15 (permalink) Old 01-11-2013, 04:39 PM Thread Starter
Thanks guys. I had heard that a combination of Velcro and 3M tape would work and never come loose, that seems to be confirmed here. My thought was to mount it like Norcal's but maybe add a velcro strap that would wrap over the amp to further secure it against the fairing. NorCal - thanks for the pics, I'm a visual learner!
post #10 of 15 (permalink) Old 01-11-2013, 08:03 PM
NorCal's Avatar
A guy who lives in Mountain View, does it on the side in his garage. He's very detailed, neat and is a perfectionist. I would recommend him highly. Anyone interested shoot me a PM.
NorCal is offline
ARC Mini 125.2 Amp and ARC Moto 602--$295 creed Parts for Sale 3 11-22-2017 05:52 PM
Arc 602 Speakers & 600.4 Arc Amp- anyone running bridged? scottrgs Audio 5 03-22-2017 07:06 AM
Arc Audio amp/speaker crossover question pointblankokc Audio 0 06-28-2014 01:36 PM
Arc Audio amp fitment question Uncle Fuzzy Audio 2 06-10-2012 10:08 PM
Arc Audio Speaker Adapter Install Help PC PaiN Audio 9 11-28-2011 05:22 PM
