Which wire is auto volume??? - Road Glide Forums
post #1 of 6 (permalink) Old 01-14-2013, 05:55 PM Thread Starter
Clutch1's Avatar
I have what I believe is a ground hum through the radio that goes up and down with speed. How do I cure that?? I cannot find the wire on the diagram.
Clutch1 is offline
post #2 of 6 (permalink) Old 01-14-2013, 07:38 PM
Roadie09's Avatar
Are you running OEM spark plugs? Some after market plugs are missing the resistor and will cause feedback through the radio.
Roadie09 is offline
post #3 of 6 (permalink) Old 01-14-2013, 09:27 PM Thread Starter
Clutch1's Avatar
Yes i am. All stock under the tank lol.
Clutch1 is offline
post #4 of 6 (permalink) Old 01-15-2013, 01:53 AM
Beavz's Avatar
Talking
I'm no audio guru, but I understand that the ground needs to be as short as possible (or it will induce the hum.)
Have you added any equipment or changed the length of your grounds?
Beavz
'11 RGU
Bug guts look better than dust on a bike... just sayin'
Beavz is offline
post #5 of 6 (permalink) Old 01-15-2013, 05:37 AM
Pin 9 of the 23 pin connector (J1850 data from the ECM) controls auto volume. It's a data line, not audio, so would not have anything to do with your issue.
The increase / decrease with the speed of the bike would probably be ignition noise getting into the ground. Check all your radio and battery grounds.
racer-x is offline
post #6 of 6 (permalink) Old 01-15-2013, 10:20 AM Thread Starter
Clutch1's Avatar
Will do. Thanks. I havent done anything to the bikes audio. Te hum just crept in last fall on the last two rides.
Clutch1 is offline
To auto-tune, or not to auto-tune Magnum ECM/Fuel Management systems 12 08-27-2014 06:25 PM
Auto tuner, which one Luis FLTRX-13 ECM/Fuel Management systems 25 04-16-2014 03:20 AM
auto tune vs no auto tune Jacket4256 ECM/Fuel Management systems 18 06-01-2013 08:12 PM
auto volume control Tom Audio 2 01-12-2013 02:55 PM
Which wire extensions? CustomGlide Controls & Handlebars 5 11-27-2010 08:09 PM
