Hawg Wired amp ground question - Road Glide Forums
post #1 of 9 (permalink) Old 01-16-2013, 10:14 PM Thread Starter
Dmize's Avatar
Installing a 6 pack from HW that includes all the wires / harnesses.
I ran the power tonight back to the battery but the ground wire is only about 2 ft long from the amp.
I've read a few posts where people are using the mounting studs for the fairing bracket....
The instructions say to look for a ground wire on the neck, but I dont see anything.
Any suggestions?
D.
D.Mize
16 CVO RGU
Dmize is offline
post #2 of 9 (permalink) Old 01-16-2013, 11:18 PM
ENG25TRK's Avatar
They probably mean the neck of the frame where the gas tank mounting bolts attach. That's where I ran my grounds from my amps. Just make sure you have a nice clean/clear contact with the bare metal.
ENG25TRK is offline
post #3 of 9 (permalink) Old 01-16-2013, 11:50 PM
T-BO 399's Avatar
I used the inner faring mount bracket
2009 FLTR, BLACK PEARL
T-BO 399 is offline
post #4 of 9 (permalink) Old 01-17-2013, 06:25 AM
+1, I used the same place, use a small file to remove the paint in around the hole and insure a good connection.
Sent from my SPH-L710 using Motorcycle.com Free App
post #5 of 9 (permalink) Old 01-17-2013, 07:17 AM
Neano62's Avatar
It is on the Neck.
I can not to save my life remember what the heck side its on?
My instructions shows X-ACTLY where it is.
I've got 2 Amps grounded there w/no Problems.
[/IMG]
Neano62 is offline
post #6 of 9 (permalink) Old 01-17-2013, 07:22 AM
h-donut's Avatar
+ 1
finally found it one day where the fairing bracket mounts to the frame
anyone try the monarchy SM70pro monoblock yet?
2010 FLTRX- r o a d g l i d e
h-donut is offline
post #7 of 9 (permalink) Old 01-17-2013, 11:11 AM
Emdog's Avatar
Re: Hawg Wired amp ground question
I grounded mine to the fairing bracket as well... no problems yet.
Sent from my Motorola Electrify using Motorcycle.com Free App
2012 FLTRX CFR slip-ons, FL-XIEDs, SE Ventilator AC
10" Windvest, Hawg Wired SX, RF PBR300x2
"Alis Volat Propriis"
Emdog is offline
post #8 of 9 (permalink) Old 01-17-2013, 11:14 AM
RGUrider's Avatar
fairing bracket as well. No problems so far (only been a few weeks, not much riding due to weather)
RGUrider is offline
post #9 of 9 (permalink) Old 01-17-2013, 07:54 PM
hogboy57's Avatar
do you have abs? where the wire run on the neck theres a loop that the wires go through the bolt that stews in to the frame is where i put my ground wire.
hogboy57 is offline
Hawg wired speaker adapter question Big_gary Audio 2 05-18-2014 04:44 PM
Hawg Wired RS400 question sharknose10 Audio 4 03-15-2014 07:23 AM
Hawg Wired question sharknose10 Audio 11 12-14-2013 08:18 PM
Hawg Wired 6.5" ZX speakers with 5.25 to 6.5 Hawg Wired adapters sloride Parts for Sale 7 11-08-2013 11:32 AM
Hawg wired Question swampking Audio 4 10-03-2012 07:54 AM
