Adding RF PBR300X4 - Road Glide Forums
post #1 of 4 (permalink) Old 02-05-2013, 08:51 PM Thread Starter
Adding RF PBR300X4
This is my first post since joining the forum, however I have been reading this forum for some time and just want to start out saying this is one of the best forums for getting help and general knowledge I've been on. I recently started an audio upgrade project on my 07 and I received a PBR300X4 amp as a gift. Can someone tell me how to set up this amp and wire the speakers. I am using the Sony DSX MS60 with Hawg Wired ZX165s-100 in the faring and added RF P165S in the lower faring along with the P1TS tweeters in the gauge holes. Any help would be appreciated.
Roadkill is offline
post #2 of 4 (permalink) Old 02-05-2013, 08:57 PM
RichieRich's Avatar
Re: Adding RF PBR300X4
What kit did you use to put the tweeters in the gauge holes?
2013 BBP FLTRX
RichieRich is offline
post #3 of 4 (permalink) Old 02-05-2013, 09:34 PM
h-donut's Avatar
just follow the basics
RCA's in
wires out
are you asking specifically if you should run the additional tweeters post ZX crossover extending the high end? I'd think so
the only other items you might need are a BT1002 if you want handlebar control and an amp bracket if you aren't into velcro
please let us know if the 4ohm stable PBR300x4 will pull both sets of tweeters
and how it sounds
2010 FLTRX- r o a d g l i d e
h-donut is offline
post #4 of 4 (permalink) Old 02-06-2013, 07:32 AM Thread Starter
I'm not planning on using a kit, I want to use the craddles that came with the tweeters and make a compression fit so I don't have to use epoxy. Modified HD guage blank outs worst case. I already made my amp bracket at work from aluminum plate. Looks like the Bagger Nation plate and I bought the Hawg Wired HSA-470 kit so I should be good to go. I'm not sure if can run the tweeters with the front speakers. They have connections on the mids for the tweeters to plug into. I was planning on running the faring speakers on the front and the RF's & tweeters on the rear.
Roadkill is offline
Rockford Fosgate PBR300X4 is here pasa Audio 82 11-07-2013 09:11 AM
JL XD400/4 vs RF PBR300x4 Amp Q-Hog Audio 30 03-24-2013 06:51 PM
Wiring the rear speakers on an RF PBR300x4 Garemlin Audio 11 01-31-2013 04:48 AM
RF PBR300x4 amp and RF speakers? GLYDDN11 Audio 2 02-02-2012 09:46 PM
Install RF pbr300x4 amp? GLYDDN11 Aftermarket Accessories 2 01-29-2012 06:45 AM
