Factory HK Radio Changes Input - Road Glide Forums
post #1 of 13 (permalink) Old 02-13-2013, 08:59 PM Thread Starter
adam_twenty6's Avatar
Anybody else have their HK radio change input on them without hitting the button on the bars? Every once in a while, the stereo will just change input. Anyone else have this happen?
2008 FLTR 105th. thundermax, rinehart true duals, custom paint, K&N High Flow, BAL tail light, 2+2 bars, -1 rear, Hawg Wired and RF Audio, avon grips and more $hit the wife don't know about, for now....
adam_twenty6 is offline
post #2 of 13 (permalink) Old 02-13-2013, 09:01 PM
Gray Beard
lundboy1's Avatar
+1 on that .... But it happens when I shut bike off and fire up it goes back to fm ... Hasn't pissed me off yet
" wishin' my knees were in the breeze!!!"
lundboy1 is offline
post #3 of 13 (permalink) Old 02-13-2013, 09:17 PM Thread Starter
Re: Factory HK Radio Changes Input
My does it going down the road. Annoying is putting it lightly. Any reason why this happens or a fix??? I pulled handle bar perches off thinking pinched wire, but nothing apparent f'd up on my part...
Sent from my SCH-I500 using Motorcycle.com Free App
post #4 of 13 (permalink) Old 02-14-2013, 06:31 AM
Handlebar switch is vibrating making intermittent contact
racer-x is offline
post #5 of 13 (permalink) Old 02-14-2013, 06:37 PM Thread Starter
Is there any way to fix that?
post #6 of 13 (permalink) Old 02-15-2013, 05:16 AM
Try cleaning it first with contact cleaner. If that does not work, the switch may need to be replaced
racer-x is offline
post #7 of 13 (permalink) Old 02-20-2013, 09:31 AM Thread Starter
Will do. Thanks.
post #8 of 13 (permalink) Old 02-24-2013, 04:20 AM
Mode switch problem
You are likely to have to replace the switch, we've seen a number of them fail already, either from vibration or the stress of replacing the switch caps with chrome ones, which can pull the switch apart from the inside! Sorry to say...
Sidecar Cycles is offline
post #9 of 13 (permalink) Old 02-24-2013, 08:27 AM
I have same issue. Listening to CD player and shut off the ignition switch. Switch it back on and it goes to radio. Not a big issue but can be annoying.
HBRGC is offline
post #10 of 13 (permalink) Old 02-24-2013, 02:26 PM Thread Starter
Sidecar, If the problem persists or become worse, how much of the handle bar control do i have to replace? Can i just replace the radio switch or must I replace the entire controller unit including the blinker, starter, ect???
changes brought changes. pauld Troubleshooting for Road Glides 3 05-11-2016 08:44 PM
Factory HK radio with CB module kyle31490 Parts for Sale 16 01-26-2016 09:10 AM
Question about stok HK head unit speaker level input to XTP Amp McGruder J&M 2 05-25-2015 09:56 PM
Wheel changes = ride changes eldridgetom Wheels and Tires 3 09-22-2013 11:06 AM
HK aux input binkley2 Audio 20 04-12-2013 02:15 PM
