Amp(s) & Electrical Issues ??? - Road Glide Forums
post #1 of 7 (permalink) Old 02-14-2013, 06:26 PM Thread Starter
Do adding amp(s) lead to issues with the electrical / charging systems on the '09 and up SERGs / CVOs ?
What~if anything~is required to remedy the issues ?
'Am in process to install J&M 7.25 Rokker XT kit in vented fairing lowers to go with the 7.25 Rokkers already in the fairing.
'Thinking about the J&M 250w Rokker Amp? Does anyone have any input on this setup, good~bad?? Does anybody have any other amp recommendations?
Thanks,
Ed
HeatWave is offline
post #2 of 7 (permalink) Old 02-14-2013, 07:10 PM
bpt-bagger's Avatar
im running a rokker 500, xt 7.25 and 6x9s love it and no electrical problems here.
bpt-bagger is offline
post #3 of 7 (permalink) Old 02-14-2013, 07:46 PM Thread Starter
How long~how many miles have you had the amp?
HeatWave is offline
post #4 of 7 (permalink) Old 02-14-2013, 07:51 PM
bpt-bagger's Avatar
one year 13k miles.
post #5 of 7 (permalink) Old 02-15-2013, 09:24 AM
UltraNutZ's Avatar
Thanks,
Ed
Thing you need to pay attention to is the class of the amp. Classes A through C are the ones you want to stay away from as they will tax your limited charging system on these bikes and will ultimately lead to one of two things happening 1.) changing audio systems 2.) replacing stock stator with more suitable stator for the electrical load.
J&M amps are Glass G so they're safe for use on stock electrical systems. Anything above Class C are good. A lot you will find are Class D and Class H.
UltraNutZ is offline
post #6 of 7 (permalink) Old 02-15-2013, 10:59 AM
DED HD's Avatar
Chainsaw has your exact set up. both Rokker 7.25" speakers in the fairing and fairing lowers with a 250 watt J&M Amp.
I initially had Rokker 7.25s in the fairing and fairing lowers, and J&M 500 watt amp, and my battery went dead. I called J&M and realized i didn't have my amp ground wire in the right place. Getting a good ground for the amp is key, and J&M recommends putting the amp ground wire where the battery's negative cable is grounded. Since then, no problems at all, and i have added Rokker saddlebag subwoofers.
'10 Red Custom:
DED HD is offline
post #7 of 7 (permalink) Old 02-15-2013, 11:28 AM
Q-Hog's Avatar
Re: Amp(s) & Electrical Issues ???
I have a JL 600/6 pushing multiple speakers w/no problem w/stock electrical system.
Sent from my PG86100 using Motorcycle.com Free App
Q-Hog is offline
2015 Electrical issues RodeGlide Troubleshooting for Road Glides 11 10-30-2018 12:24 PM
Electrical issues. Need Help!!! Kooljay Engine Related 6 07-07-2017 12:23 PM
electrical issues bigdoug1130 Troubleshooting for Road Glides 11 06-02-2017 10:12 AM
Recurring theme: electrical issues following 14" Malo bar install slowride Troubleshooting for Road Glides 15 12-01-2015 12:23 PM
Possible Electrical Charging issues??? paco ritter Troubleshooting for Road Glides 5 10-05-2012 09:26 PM
