Is factory HK a 4 channel output? - Road Glide Forums
post #1 of 27 (permalink) Old 02-20-2013, 09:35 AM Thread Starter
adam_twenty6's Avatar
I am interested in adding the inner fairing speakers to my setup. I know an amp would work best, but if I can't afford one now, can the factory hk go 4 channel?
Sent from my SCH-I500 using Motorcycle.com Free App
2008 FLTR 105th. thundermax, rinehart true duals, custom paint, K&N High Flow, BAL tail light, 2+2 bars, -1 rear, Hawg Wired and RF Audio, avon grips and more $hit the wife don't know about, for now....
adam_twenty6 is offline
post #2 of 27 (permalink) Old 02-20-2013, 10:19 AM
Yes but it needs to be turned on by the dealer I've heard.
post #3 of 27 (permalink) Old 02-20-2013, 10:39 AM
JJSW1283's Avatar
Do you have an ultra or custom?
JJSW1283 is offline
post #4 of 27 (permalink) Old 02-20-2013, 10:47 AM
A firmware update by the dealer and you are good to go~you will have "fade"
HeatWave is offline
post #5 of 27 (permalink) Old 02-20-2013, 12:24 PM
skratch's Avatar
the radio will have 4 channel output, but may have to be flashed for the fader operation to work. some have added speakers and their fader was already activated.
skratch is offline
post #6 of 27 (permalink) Old 02-20-2013, 01:24 PM
RoadGlideRider's Avatar
All four speakers are active from the factory. Just not pluged in.
The only thing the Dealer Activation does is enable the "Fader" control.
Go throught the Audio controls and look to see if "Fader" shows up on the display.
If it does, you don't need the Dealer activation, just the speaker wires pluged int he housing.
RoadGlideRider is offline
post #7 of 27 (permalink) Old 02-20-2013, 03:59 PM Thread Starter
Re: Is factory HK a 4 channel output?
It is an '08 and NOT an Ultra. not sure about the custom part though.
post #8 of 27 (permalink) Old 02-20-2013, 04:35 PM
Where is the fade button?
post #9 of 27 (permalink) Old 02-20-2013, 04:40 PM
Mike U's Avatar
Gary, I believe that you hold in the volume button on the left control.
That will bring you to the bass, treble, balance, volume settings.
I think the fade setting is in there also.
If it's not there its not activated.
Anyone please correct me if I am wrong.
Thanks!
Mike U.
USMC 1975-1977
Semper Fi!
Nothing else matters!
Mike U is offline
post #10 of 27 (permalink) Old 02-20-2013, 04:48 PM
Thanks!
Mike U.
Ya that's what I thought. I don't have fade or balance. You would think everything should be activated regardless of having two or four speakers.
Factory 2010 HK (Blue L.E.D. Display) sharknose10 Miscellaneous for Sale 3 04-12-2014 10:38 PM
Factory HK Radio Changes Input adam_twenty6 Audio 12 02-24-2013 07:38 PM
Pre amp Output Install on HK Radio pblot Audio 7 09-04-2012 04:42 PM
Factory HK Head Unit from 2012 Willy_B Sold 5 08-26-2012 09:22 AM
Rear speaker output from HK head unit Mlangfelder Audio 6 03-29-2011 02:23 PM
