04 RG audio capable of 4 ohm load - Road Glide Forums
post #1 of 3 (permalink) Old 02-23-2013, 10:32 AM Thread Starter
Clutch1's Avatar
Can i drop the speakers to a 4 ohms set using the stock radio and no amp?
Clutch1 is offline
post #2 of 3 (permalink) Old 02-23-2013, 12:18 PM Thread Starter
Clutch1's Avatar
Ok, I was being cheap. Ordered the Hawg Wired amp and speakers kit with harness. Should be here in 7 days.
Clutch1 is offline
post #3 of 3 (permalink) Old 02-23-2013, 04:19 PM
thedude's Avatar
You made the right choice.
thedude is offline
Paralleling speakers 4 ohm 2 ohm using amp set up to parrallel Heavy Metal Audio 16 01-06-2018 06:09 PM
Speaker question 2 OHM or 4 OHM Ginee13 Audio 3 09-22-2015 05:53 AM
switching from 4 ohm to 2 ohm at a later date chevjerico Audio 3 05-15-2014 01:24 PM
4 ohm and 2 ohm speakers yamahoe72 Audio 7 04-13-2013 07:55 PM
hogtunes ohm load? dirtracer27x Audio 1 03-09-2012 12:45 AM
