Quick amp question - 2 vs 4 channel - Road Glide Forums
post #1 of 10 (permalink) Old 02-27-2013, 06:09 PM Thread Starter
Garemlin's Avatar
Just curious if anyone is running a 2 channel amp for the front speakers and running their rear speakers off of the stock or aftermarket head unit??? Still planning my audio upgrades and just don't know if it is worth it to get a 4 channel amp to power the rears when I don't really hear them that much anyway. Wife can hear them good now stock so it should be better with aftermarket speakers and the extra juice of an aftermarket head unit.
Thoughts???
Garemlin is offline
post #2 of 10 (permalink) Old 02-27-2013, 06:22 PM
Chester's Avatar
I have Hogtunes 4 channel. When I bought my bike I asked for the RGU package and they mistakingly put in the new 2 channel higher output unit. I did not like it at all. The rear speakers sounded terrible without the amp. They swapped it out for me at no charge and I could not be happier. IMHO the 4 channel is better. Good Luck!!
2012 RGU, Ember Red Sunglo,
REMEMBER WHEN SEX WAS SAFE AND MOTORCYCLES WERE DANGEROUS???
Chester is offline
post #3 of 10 (permalink) Old 02-27-2013, 07:27 PM
h-donut's Avatar
new radio will be much cleaner for sure v. stock, because it will have better EQ rear speakers should cut better, speaker lids might help when you decide to get the amp. could run four in back
2010 FLTRX- r o a d g l i d e
h-donut is offline
post #4 of 10 (permalink) Old 02-28-2013, 04:30 AM Thread Starter
Garemlin's Avatar
Not really interested in adding more speakers to the rear. If anything maybe lowers somewhere down the line. So you think it wouldn't be bad running a decent set of rear pod speakers off a Sony h/u and the fronts on an amp???
My debate is getting the Hog Tunes 4ch set-up which is 40w x4 or just the 70w x2 for pushing the front.
Garemlin is offline
post #5 of 10 (permalink) Old 02-28-2013, 04:54 AM
Brewiz's Avatar
I'm running a PBR 300x4 with Hertz in the front and Polks in the rear, I can tell a huge difference. May not hear the rears all the time but as soon as I turn my head a little they are there....Plus, I'm getting ready to add to the lowers with a pair of HW ZX 6.5's and the CS300.
Brewiz is offline
post #6 of 10 (permalink) Old 02-28-2013, 06:16 AM
09Sharknose's Avatar
I'm running a HW RS400 to 4 speakers on the front channels, and still running the TP speakers in stock configuration. Haven't had any problems.
I do plan to upgrade next winter though. Gonna go with another 4 ch amp to the TP and the saddlebags.
09Sharknose is offline
post #7 of 10 (permalink) Old 02-28-2013, 06:48 PM
UltraNutZ's Avatar
Thoughts???
Radio is what's going to make the difference for you even with stock speakers. Problem is aftermarket radios are almost never 2 ohm stable in that setup so you'd have to change speakers as well.
Put 4 decent speakers in there, put a decent 4-channel amp on them, then take off down the road and fade all the way to the front and tell me it doesn't make a difference. It does, even at highway speeds. Stock sucks so I see where you're coming from in thinking it doesn't.
2012 FLHTK - VTPBB
UltraNutZ is offline
post #8 of 10 (permalink) Old 03-01-2013, 01:24 AM
RoadGlideRider's Avatar
Thoughts???
I'm running the Hawg Wired DCS 2 speaker amp/speaker system on my front speakers. But on my Tour Pak is just the stock speakers. I have the detachable kit on my Tour Pak and only use it when on trips. So the front speakers are the ones I use most of the time. When I have the Tour Pak on the bike with a Passenger, we mostly use the head sets. When the rear speakers are on, they are mostly used as back ground support.
RoadGlideRider is offline
post #9 of 10 (permalink) Old 03-01-2013, 07:04 AM Thread Starter
Garemlin's Avatar
Oh I plan on replacing the rear speakers. They do suck. I just figure the majority of the sound will be heard at the front so no need to spend the extra money for an amp. I'm thinking a decent set of 4ohm speakers in the rears powered off the Sony head unit will be plenty for as much difference that they make at cruise speeds. May consider adding an additional amp down the line for some lower speakers.
But after having three Street Glides in the past with nothing but front speakers and my wife telling me that she heard the fronts on those better than she hears the rears on bikes I have had with four speakers at any speed tells me something. Spend the money where it be best utilized. More power in the front.
Garemlin is offline
post #10 of 10 (permalink) Old 03-01-2013, 07:43 AM
UltraNutZ's Avatar
most definitely correct. What's in your face is what you want to pay attention to first whether it be simply fairing speakers or lowers too. Then you worry about the rears.
2012 FLHTK - VTPBB
Stock vs Arnott vs Legends vs HD Premium SEUGOT1 Suspensions 15 04-25-2017 10:10 AM
Thundermax vs DynoVision vs PwrPro Black vs FP3 stillsoldier4christ ECM/Fuel Management systems 16 10-01-2016 12:42 AM
J&M 2013 RGU, 4 Channel 360W amp plug32 J&M 0 04-25-2015 10:37 AM
FS: J&M 500W 4-channel Rokker Amp. Cheap! JayKS Parts for Sale 5 02-20-2015 02:39 PM
2 Channel Amp/4 Speaker Question Fahred Audio 1 04-03-2012 04:28 PM
