Newb willing to install 2 PBR300X4 - Road Glide Forums
post #1 of 23 (permalink) Old 02-27-2013, 09:13 PM Thread Starter
I admit I have no idea about installing and setting up a complete new audio system, but with your guidance, I will get it completed. I will install a JVC Arsenal KD A-95BT in-dash with 2 RF 300X4 amps. At first, I will have the amps in 2 channel mode to run 4 speakers in the inner fairing; provides growth for additional 4 more speakers (lids / lowers). I get lost when trying to figure out what wiring/additional equipment I need for the install. Once wired, I have no idea how to set up the amp, but I'll worry about that after just getting past the install.
1. I think I need a distribution block, but don't know which one I need. I've seen fused, not fused, and different gauge wiring size in and out.
2. What gauge wires do I need? I've read 8 GA from battery to block, then 10 GA from block to amps. Just not sure.
3. Do I need fused wire if the distribution block is already fused, or vice versa? Is one way better than the other?
Thanks for the help
V/r
2016 CVO Road Glide
SMSgt B is offline
post #2 of 23 (permalink) Old 02-27-2013, 11:24 PM
Re: Newb willing to install 2 PBR300X4
If you haven't already purchased the amps, I would go with the 300×2 instead of the 300×4, more adjustable and just a better amp IMO. Running an 8 guage wire is fine. I ran 8 guage with the fuse under the seat, it goes to the faring, there I have a 1-4 to 4-8 wire distribution block, I just use one side, I still use 8 guage to go to the amps.
post #3 of 23 (permalink) Old 02-28-2013, 01:03 AM
h-donut's Avatar
dbell66253 is right
8 gauge is sufficient, a true spec like EFX kit from walmart, or knu concepts on amazon, the two kits on amazon are tin over alum and copper over alum.
the copper one is more expensive, both are good each under $30
most single amp kits have a 60 amp fuse included, plastic barrel type, I bought the lightning audio dual fuse block from ebay, $9 with 4 fuses, got 2 30 amp and 2 40 amp.
I have my fuse under my seat, went 4 ga to 8ga x2, I think the 4 ga was overkill, it's only a one foot run, everything else is 8ga
I grounded to my frame, sometimes people prefer grounding back to the battery
+1
PBR300x2, 2 channel is a better amp, I have 4 front speakers hooked up to one and it's very clean and loud, I had the PBR300x4, it was harder to fine tune, or damn near impossible to find the breakup points
that's just because rockford came out with the PBR300x4 first
keep us posted
2010 FLTRX- r o a d g l i d e
h-donut is offline
post #4 of 23 (permalink) Old 02-28-2013, 06:20 AM
09Sharknose's Avatar
If you've never installed an amp before, I would opt for a more plug and play type setup. With the RF, you're going to be splicing wires unless you have all of the little connectors and the skills to install them correctly. I haven't seen an installation kit for the RF yet that makes the connections for you without cutting wires.
09Sharknose is offline
post #5 of 23 (permalink) Old 02-28-2013, 06:41 PM
UltraNutZ's Avatar
Thanks for the help
V/r
do yourself a favor and forget that you ever knew that PBR300x4 part # existed. There is much better to be had for about the same $ and I'm specifically speaking of the Soundstream PN4.520D. Provides the same configuration options with the 1 MAJOR exception that the SS is 2 ohm stable and the RF is not (4 channel). Couple that with 520w of nice clean Class D power that won't tax your stock charging system. SS amps run cool to the touch.
1. You don't need a distribution block. Simply run 2 seperate 10ga solid strand power wires to your battery, fuse each one independently AT THE BATTERY for your situation. The SS, use 30A fuses.
2. 10ga solid strand wire you can pick up at AutoZone is perfect. You can get the fuse holders there too.
3. See 1 and 2 above.
2012 FLHTK - VTPBB
UltraNutZ is offline
post #6 of 23 (permalink) Old 02-28-2013, 07:21 PM Thread Starter
All,
Thanks for the guidance so far and it seems I should have waited to purchase other amps, but I've had these amps sitting in the garage since they first came out. So I might as well use them.
So either I can block it or just run 2 separate lines from the battery. Make sure I fuse at the battery.
2016 CVO Road Glide
SMSgt B is offline
post #7 of 23 (permalink) Old 02-28-2013, 07:39 PM
h-donut's Avatar
I'll try and help
30amp fuses or better to each amp, so fused distribution block
where you place fuse block is up to you.
more accessible under the seat,
less cable to run if placed under fairing
I have one PAIR of amp mounts if you need them
Will have more soon, have been working on another project.
h-donut is offline
post #8 of 23 (permalink) Old 02-28-2013, 08:08 PM Thread Starter
Originally Posted by h-donut View Post
I'll try and help
Understand and thanks for the help. Also, I already have a pair of your amp mounts for the install.
2016 CVO Road Glide
SMSgt B is offline
post #9 of 23 (permalink) Old 02-28-2013, 09:39 PM
pacmanrr's Avatar
How much better are the Soundstream amps? Are they easier to tune and mount? Im upgrading my system too and im in the market for a decent amp
pacmanrr is offline
post #10 of 23 (permalink) Old 02-28-2013, 10:55 PM
h-donut's Avatar
you ordered your brackets on 10/25/2012 7:16p 16th person to order
brackets #22 and #23, left and right side, so sorry, and I appreciate your support
I have cabin fever I guess, no disrespect meant or intended
do you have adaptor rings and speakers yet?
I enjoyed most of my install except the soldering, good adapter rings help
I fought with the throttle up rings and got a little frustrated with the speaker output soldering
doing my bars the last couple days, soldering is getting easier
here's where I put my fuse block
then made an side mount ring terminal
^^^^^^^ above ^^^^^^^^^^
I did have to cut my battery box top cover on the positive side, you can just barely see it, but I removed a good portion of the corner, stuff was just getting too tight
h-donut is offline
Map of members willing to help members? turbochrisb Road Trip Discussions/Stories/Pictures 8 08-29-2017 10:04 AM
Alaska this summer the Lord willing. roadglidetouring Organize Rides Here 4 02-15-2014 03:43 AM
Install RF pbr300x4 amp? GLYDDN11 Aftermarket Accessories 2 01-29-2012 06:45 AM
