ohms for rear speakers - Road Glide Forums
post #1 of 6 (permalink) Old 03-04-2013, 09:57 PM Thread Starter
I just run across a question about speakers for my 08 RG. Something was said about having speakers with the correct ohms for my bike. How do I know what ohms I need to have. I don't know what bike the speakers came off of. The radio that I have is a harley radio and as far as I know it is the one that would have came with the RG.
Thanks for any help.
roadglide_08_2012 is offline
post #2 of 6 (permalink) Old 03-04-2013, 10:23 PM
Triplej's Avatar
My stock rear Tour Pak speakers are 2 ohm. Hope that helps.
Triplej is offline
post #3 of 6 (permalink) Old 03-05-2013, 06:25 AM
mocotom's Avatar
If your radio is the stock Harmon Kardon (06 to 13) it is a 2 ohm system.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #4 of 6 (permalink) Old 03-05-2013, 06:36 AM
tmd
Pre 06 is 4 ohm, 06 and newer is 4 ohm.
tmd is offline
post #5 of 6 (permalink) Old 03-05-2013, 07:57 AM
JMJOHN
JMJOHN's Avatar
1989-1997 stock Harley audio systems require external speakers with a minimum impedance rating of 4-ohms ,,,,,
1998-2005 stock Harley audio systems require external speakers with a minimum impedance rating of 8-ohms ,,,,,,,,,((2004-2005 special Screaming Eagle radio, 4-ohm minimum))
2006-2013 stock Harley audio systems require external speakers with a minimum impedance rating of 2-ohms ,,,,,
these are only MINIMUM values, as you can go as high as 16 ohms on any of them without issues ,,,,,
JMJOHN ----
JMJOHN is offline
post #6 of 6 (permalink) Old 03-05-2013, 08:13 PM Thread Starter
Thanks for the help guys. I checked today and the speakers that I have are 2 ohm so I should be good to go there, now all I need is ti wire them. If I can't find a plug & play harness I will wire them in as h-donut explained.
Thanks again
hope that I can help you guys sometime.
Can Someone Explain Ohms To Me? The Volusianator Audio 15 06-20-2018 11:25 AM
4 ohms - 2 ohms T-BO 399 Audio 4 07-10-2015 10:47 PM
Ohms and wiring (series v parallel) RedneckMedic66 Audio 7 03-30-2014 03:49 PM
Will This Work/Reduce My Ohms? The Volusianator Audio 6 11-23-2013 03:30 PM
? About ohms Willy_B Audio 14 04-09-2012 06:40 AM
