Which 2 channel amp? - Road Glide Forums
post #1 of 12 (permalink) Old 03-05-2013, 07:55 PM Thread Starter
If price is not a factor which is the better amp the Arc 125 x 2 mini or the Rockford pbr 300 x2? The amp is going to push a set of 4 ohm Focals in the fairing. Any responses would be greatly appreciated. Thank you.
gplatt58 is offline
post #2 of 12 (permalink) Old 03-05-2013, 08:10 PM
Price not a factor, go Hawgwired.
post #3 of 12 (permalink) Old 03-05-2013, 08:34 PM Thread Starter
The guy who is going to help me install will give me an arc for the same price as the pbr.
gplatt58 is offline
post #4 of 12 (permalink) Old 03-05-2013, 08:43 PM
Ok, I have two PBR 300X2s mounted now, waiting for a part to do the Hawgwired. I like the RF's a lot, I don't have an ARC, so I can't tell you about them. The Rockfords have been good, and don't take much space. Hopefully somebody will chime in who has had ARC and Rockford.
post #5 of 12 (permalink) Old 03-05-2013, 08:47 PM
pat123's Avatar
I have a Arc 125 x 2 mini running a set of hertz 6.5's and I'm impressed with the amp. I have the gain 1/2 way up and it's loud and clean.
pat123 is offline
post #6 of 12 (permalink) Old 03-05-2013, 09:09 PM Thread Starter
The guy helping me has both and has used both amps and is really pushin the Arc, just thought i'd get some more opinions on the matter. Thanks for the responses and keep them coming. Install is Saturday.
gplatt58 is offline
post #7 of 12 (permalink) Old 03-05-2013, 09:13 PM
If the guy you have doing the install prefers the ARC, ask him why, if it makes since, go with that, unless you have another reason to go with the other amp. Is there any possibility that you may want to add more to your system at a later date?
post #8 of 12 (permalink) Old 03-05-2013, 09:34 PM Thread Starter
I have the 4 channel pbr pushing 4 rockfords in the faring now and replacing those four with focals and throwing another set of focals in the rear pods so I need a two channel to push my higher rated focals in the stock faring position. I blew through my buget with those speakers so i was originally thinking pbr until I talked to him today.The Hawg Wired amps are going to have to wait til next years tax returns. Thanks
gplatt58 is offline
post #9 of 12 (permalink) Old 03-09-2013, 01:03 PM
I have what is essentially a 125 x 2 Arc made by Wetsounds with four ZX165 Hertz HE that are replacing 4 Alpines, the amp ran good with the Alpines, haven't heard the Hertz yet, putting WO502s on and not done yet. I looked into JL and that is a good option but if I was to change, I'd go Hawgwired, made for a bike, low current draw which means less heat, the virtual enemy of an amp and plug and play.
Randy D.
Kristie D. Angel On My Shoulders October10, 1973-April 16, 2009
Big Dog is offline
post #10 of 12 (permalink) Old 03-09-2013, 08:24 PM
The Arc also has low draw. Its a very clean amp. The Arc's are used with high end Focal's. Must be a good reason. I was able to afford any of the set ups out there (within reason) and I went with the Arc and the Focals. Absolutely no regrets!
inferno1976 is offline
*Which Pistons?? Which Tuner??* HELP! Iron1 Engine Related 2 02-08-2017 07:15 PM
Which 4 channel Amp for 2015 RGS nking262 Audio 9 07-24-2015 03:23 AM
J&M 2013 RGU, 4 Channel 360W amp plug32 J&M 0 04-25-2015 10:37 AM
FS: J&M 500W 4-channel Rokker Amp. Cheap! JayKS Parts for Sale 5 02-20-2015 02:39 PM
Bazooka MC-HD-AMK 4 Channel Amp? EricFLTRU Road Glide Specific Discussions 4 06-07-2011 02:12 PM
