Rear facing aux input - Road Glide Forums
post #1 of 7 (permalink) Old 03-08-2013, 12:47 PM Thread Starter
binkley2's Avatar
The other day I ran across a thread, with photos, explaining how to install a rear facing auxillary input on the HK. Does anyone recall seeing this thread and if so, do you recall what it was called? I tried the search but must be missing a keyword somewhere. HELP!
binkley2 is offline
post #2 of 7 (permalink) Old 03-08-2013, 12:49 PM
Zog
Zog's Avatar
http://blog.ironacesspeedshop.com/ho...vidson-stereo/
try this link
2009 Black pearl 110ci,D&D exhaust, titanium gauges, Bright ass lights tailight, madstad windshiled, jac-knife highway pegs, progressive monotones, Ness Deep Cut Hot Legs etc..etc..etc...
Zog is offline
post #3 of 7 (permalink) Old 03-08-2013, 01:05 PM Thread Starter
binkley2's Avatar
Exactly the piece I was looking for. Thanks Zog.
binkley2 is offline
post #4 of 7 (permalink) Old 03-10-2013, 09:07 PM
adam_twenty6's Avatar
I did this little mod and it works rather nicely.
1 issue though... it seems the right channel has more volume than the left channel when on AUX.
the aux cable I used was a male/male cable, same one i was using in the front of the radio. I cut one of the ends off to get to the wires. There were only 2 insulated wires and 1 bare braded wire. I put the red to the left and the black to the right, following the only color that matched up from the pictures on the blog to the AUX cable. After a little searching, red=right, black=left seems to be a common rule, so maybe i need to redo my soldering.
could a weak solder connection on the left channel hook up cause that?
could crossing the input cause a poor signal on 1 channel or the other?
Radio and CD do not seem to have the weak left channel problem. Any help from someone who know more about wiring than I do would be appriciated.
2008 FLTR 105th. thundermax, rinehart true duals, custom paint, K&N High Flow, BAL tail light, 2+2 bars, -1 rear, Hawg Wired and RF Audio, avon grips and more $hit the wife don't know about, for now....
adam_twenty6 is offline
post #5 of 7 (permalink) Old 03-10-2013, 09:11 PM
BigB64's Avatar
Did you not like the iron aces phone mount on speedo and tach! I have installed two but I like it. Or are you trying to run cable to iPod in box? Either way it looks good but the aces wiring charges while you ride! That's for long days
If you dont like what she is saying,Go for a ride
BigB64 is offline
post #6 of 7 (permalink) Old 03-10-2013, 09:25 PM
i use an android phone, so just get aux cord to glove box and off the dash.
post #7 of 7 (permalink) Old 03-10-2013, 09:50 PM
BigB64's Avatar
Nice and clean
BigB64 is offline
How to use multiple inputs to HD aux stereo input??? paco ritter Audio 20 10-05-2013 06:28 PM
Rear Facing AUX. Need some help. adam_twenty6 Audio 15 04-07-2013 11:53 PM
Rear AUX input question ksarauer Audio 3 05-21-2012 11:21 PM
Harmon Kardon - Aux Input not working gbourdon Audio 3 04-16-2012 09:56 AM
Aux input relocation dbutler27 Audio 4 11-25-2011 10:53 PM
