Amp & Speakers: Bang for the Buck - Road Glide Forums
post #1 of 35 (permalink) Old 03-11-2013, 07:23 PM Thread Starter
Torquey's Avatar
Yes, I've searched this Forum and have found some good information. However, I am wondering if the items that I am leaning toward can be beaten in terms of getting even better sound for about the same money. I do not blast music, but the distortion of the stock set up is horrible.
On my FLTRX, I am staying with a 2 speaker set up in the fairing and want to keep the audio items stock looking if possible. Therefore, no rear bag speakers, no speakers in lowers, no removal of gauges to install tweeters, etc. I was planning to add the following:
Rockford Fosgate PBR 300X2 2 channel amp
Polk Audio MM651 6.5" Coax speakers
I would like to hear from those experienced in this area a number of things including:
What would you prefer as a package for the same money?
Who makes adapter rings for the rounds that wont kill me during installation?
Is it worth putting those "foam cups" of any sort around the back of the speaker or lining any cavity with foam, etc.?
Should the gain, etc., be changed in the stock head unit and what are the favored gain settings on the amp itself (PBR)
I know it's a lot to ask, but I thank all who respond very much!
Torquey is offline
post #2 of 35 (permalink) Old 03-13-2013, 07:59 PM
adam_twenty6's Avatar
I think that amp will cook those speakers over a couple months time.
2008 FLTR 105th. thundermax, rinehart true duals, custom paint, K&N High Flow, BAL tail light, 2+2 bars, -1 rear, Hawg Wired and RF Audio, avon grips and more $hit the wife don't know about, for now....
adam_twenty6 is offline
post #3 of 35 (permalink) Old 03-13-2013, 08:37 PM
you shouldnt have a problem with that setup... you will only fry a speaker if you turn the gain up too high.... turn your gain on the amp all the way down, and turn the volume up to 12-13 bars (just under the "E" in volume)(factory radio output signals distort shortly thereafter so no reason to crank it full volume) and adjust the gain accordingly. turn it up slowly until the speaker starts to distort, then back it off a little bit... youll be fine..
bronzerx7 is offline
post #4 of 35 (permalink) Old 03-13-2013, 08:41 PM
FLIronButtRider's Avatar
[post deleted. I was thinking of the 300x4 amp]
Mike-FLIronButtRider
2011 Road Glide Custom 103
2008 KLR650
FLIronButtRider is offline
post #5 of 35 (permalink) Old 03-13-2013, 08:41 PM Thread Starter
Torquey's Avatar
Wow! 76 views but you are the first post. Perhaps my questions were too dumb. However, thank you VERY MUCH for your response!
In mobile audio as in home audio, most speakers cook (literally, at the voice coil) from too little power in an amp being driven hard to compensate for its weakness trying to produce volume. The amp puts out about 150 Watts per side.
Conversely, a high powered amp generally emits clean power and does not heat up the voice coil of a speaker by passing distorted squared off waves (very over simplified explanation) from being over driven.
At home, though I listen at soft to moderate levels, I have thousands of watts in my systems with no blown drivers. It's sort of like asking a 125cc bike to have gobs of low end V-Twin torque.
However, if I'm missing something please repost, since I know ZERO about this mobile audio stuff though I try to read up on it. All I know is that the stock system is downright embarrassing.
Thanks again.
Torquey is offline
post #6 of 35 (permalink) Old 03-13-2013, 08:42 PM Thread Starter
Torquey's Avatar
Excellent! Thank you!
Torquey is offline
post #7 of 35 (permalink) Old 03-13-2013, 08:45 PM Thread Starter
Torquey's Avatar
Thank you as well! Yeah, all I want is two speakers. I am looking for clean, fairly accurate, and low priced. If I want music reproduced more accurately, I'll take my Vacuum Tube preamp and amps and my Planar speakers at home and forget about trying to be too picky with the V & H Monster Rounds!!!
Torquey is offline
post #8 of 35 (permalink) Old 03-13-2013, 08:47 PM
also, i used a set of flat speaker adapters as opposed to the cone shaped to allow for a deeper speaker depth (everyone will have their own opinions on this). no need to use the foam cups on the back of the speaker, however some light sound deadening material (jm rokker makes a great pre made kit) will help out with cancelation of bouncing sound waves inside of the fairing itself which will improve bottom end by just a smidge. you will also want to use a high/low level converter with the rca input of the amp instead of just high level itself. reasoning behind that being that the rockford amps accept between 4 and 6v off of the high level input for amp turn on. however, factory harmon kardon seems to put out a little more voltage, so anything over the 6 volts is fed back into the radio keeping it on after the switch is shut off. like i said man, you sound like you are pointed in the right direction, if you have any more questions dont hesitate to ask..
post #9 of 35 (permalink) Old 03-13-2013, 08:47 PM Thread Starter
Torquey's Avatar
I GREATLY appreciate the responses. Please keep them coming, especially about the relative bang for the buck of these particular components, lining the speaker cavities (with whatever) and a good adapter ring set up for the 6.5s.
Thanks again (and again).
Torquey is offline
post #10 of 35 (permalink) Old 03-13-2013, 08:48 PM
and im spent...lol
better bang for more buck. seethesvt Audio 10 04-09-2015 11:36 PM
Best Bang for the Buck ? bulldog68 Engine Related 29 10-02-2013 06:42 AM
this seems like a good bang for the buck! burnah Videos 7 04-21-2012 04:48 PM
Bang Bang Pulled the triger 01se vs 09 rg havnfun *General Road Glide Discussions/Pictures 13 07-01-2010 05:32 PM
