Rear Facing AUX. Need some help. - Road Glide Forums
post #1 of 16 (permalink) Old 03-11-2013, 08:24 PM Thread Starter
adam_twenty6's Avatar
I saw the thread about getting the AUX wire ran thru the back of the HK and wanted to do it since that is the input I use most. I ran a cable into the back of the HK and soldered the wires into place. Then I cut the board where it showed so the AUX input would be active without the plug in the face of the HK.
Then I plugged in my ipod and the left speaker is really weak. I changed to my phone AUX, still weak left signal. Used another AUX cord and plugged into the front of the HK, still weak left signal. Re-Soldered the wires to the board, still weak left signal.
I double checked the Red-Right, Black-Left. they are hooked up correct. All 3 wires on AUX cable ohm out. There is 200 ohm resistance between all three of the AUX jack points on the board. CD player and radio do NOT have weak left signal. both right and left channels have same volume output on those sources.
Could it be possible that I cut the board too deep and possilby cut thru a portion of the left channel signal conductor? Any input would be helpful. I don't want to replace the HK if I don't have to. Mainly because I don't want to shell out the $$ for the hand control adaptor.
Thanks
2008 FLTR 105th. thundermax, rinehart true duals, custom paint, K&N High Flow, BAL tail light, 2+2 bars, -1 rear, Hawg Wired and RF Audio, avon grips and more $hit the wife don't know about, for now....
adam_twenty6 is offline
post #2 of 16 (permalink) Old 03-12-2013, 05:55 AM
Yea...you cut it too deep.
Cutting the trace is not the proper way to do that. The circuit should have been modified.
Try Iron Cross Audio, they can probably get you straightened out.
racer-x is offline
post #3 of 16 (permalink) Old 03-12-2013, 08:10 AM
The cut was way too long.
Use these directions: http://www.hdbomm.com/Aux_Cable_on_Harmon_Kardon.doc
pilot is offline
post #4 of 16 (permalink) Old 03-13-2013, 11:17 AM
phoenix9222's Avatar
Link problem
Link didn'twork for me, I found it by going to http://www.hdbomm.com/index.html
then scrowl down to the thread for
Rear Auxiliary Input Jack Modifications for the Harmon Kardon Radio
hope this helps.
2011 Road Glide Ultra (Black)
no cat, CVO mufflers with 2" full-sac baffles
Wild One Chubbys 10"
Detchable Tour Pak
Stage 1
Rear Facia Install
14" WindVest
Cobra Powrpro FI2000
Polk MM651, speakers in faring
Polk MM521, speakers in tourpak pods
phoenix9222 is offline
post #5 of 16 (permalink) Old 03-13-2013, 11:33 AM
sdlakerfan79's Avatar
Thanks for this info... i always thought cutting the trace was the only way to go.
sdlakerfan79 is offline
post #6 of 16 (permalink) Old 03-13-2013, 11:45 AM
DED HD's Avatar
Unfortunately you did not know about the new way to 'trick' the unit that something is plugged in to the aux jack in front. Rather than cutting the trace, the new way requires you to remove an inductor from the circuit board using a pencil solder.
Otherwise, make sure you have a good solder on the left+, and/or check to make sure you have the common -wire and the left+ and right+ wires in the right location.
hope you can get it fixed!
'10 Red Custom:
DED HD is offline
post #7 of 16 (permalink) Old 03-14-2013, 09:01 PM
Thanks
I did the same thing and cut too deep, I am sending my radio into iron cross so they can fix it as soon as I get my bike back.
Sent from Motorcycle.com App
ksarauer is offline
post #8 of 16 (permalink) Old 03-14-2013, 09:24 PM Thread Starter
How much did they quote you for the fix? I am on the fence about replacing the HK for an aftermarket head unit.
post #9 of 16 (permalink) Old 03-26-2013, 06:31 AM
outlawjessejames's Avatar
DED - which inductor are you talking about? I'm considering doing this mod today and want to make sure that I don't mess ANYTHING up!! I looked at the Iron Aces write and they make it sound simple but most on here seem timid about doing this.
Thanks,
Outlaw
2012 Ultra Custom - Big Blue Pearl
outlawjessejames is offline
post #10 of 16 (permalink) Old 03-26-2013, 06:55 AM
Smile
Thanks,
Go to http://www.hdbomm.com/index.html
pilot is offline
Facing facts Singlebeam General Off-Topic Discussions 34 11-11-2016 07:52 PM
Front & facing cameras? JG762 *General Road Glide Discussions/Pictures 6 08-03-2016 07:19 PM
Front facing/ram air cleaner, good/bad? Torkmnstr Intake and Exhaust 4 04-24-2014 10:18 PM
Rear facing aux input binkley2 Audio 6 03-10-2013 09:50 PM
