No sound to rear speakers - Road Glide Forums
post #1 of 15 (permalink) Old 03-16-2013, 09:51 AM Thread Starter
Just installed HD Boom saddlebag lid speakers on 13 FLTRX should they be working, i've read yes i've read no I know the fade won't work without dealer upgrade, the owners manual said it's not equiped. So does the dealer also turn on the other 2 channels? Parts guy says yes, i just wanted to ask you guys, so i can put it back together. Thanks
I should add that I also put in the Boom amp with the overlay harness.
2013 FLTRX Candy Orange/16" Madstad/Fuel Moto Jackpot SS 2/1/Power Vision/Daymaker/CD LED's Plasma Rods/Boom saddlebag speakers/amp/Heritage Strech Bars/Zumo 660
ZAKMANDO is offline
post #2 of 15 (permalink) Old 03-16-2013, 10:32 AM
No. The rear speaker out put is on from the getgo. The only thing the dealer will do is flash the cpu so you will have fader control.
I am assuming your riding a Custom and not a ultra. The ultra should already have the fader.
post #3 of 15 (permalink) Old 03-16-2013, 10:59 AM Thread Starter
I don't know what I did wrong then, I followed the install intsructions to the letter, and rechecked it. Yes it's a Custom.
Just talked to parts guy said software in my bike is for only 2 channel, with the Boom.
Some other systems you may not have to do it I don't know, we shall find out. When ever it quits snowing.
ZAKMANDO is offline
post #4 of 15 (permalink) Old 03-17-2013, 02:37 PM
hmm.... was it a plug and play setup? (just asking cause i do not know). re check you're rear pin outs again to make sure you have the correct leads. they will be:
pin 1 - right rear +
pin 2 - left rear +
pin 24 - right rear -
pin 25 - left rear -
bronzerx7 is offline
post #5 of 15 (permalink) Old 03-17-2013, 05:10 PM
ENG25TRK's Avatar
Like bronzerx7 says, make sure the speakers are plugged into the right pins. It's the output on the right side when looking at the back of the radio.
A good thread about this topic:
https://www.roadglide.org/showthread....t=Rear+speaker
Are you running an amp? If so, make sure there's power to the amp. If not, check your fuse and your ground. Most amps have a power light that indicates its working.
ENG25TRK is offline
post #6 of 15 (permalink) Old 03-17-2013, 05:21 PM
The plugs coming off the head set are different on the Custom and the Ultra. I was talking about the head set only putting out rear power. You will need to buy the four channel plug or tap into the pins like these guys are talking about.
post #7 of 15 (permalink) Old 03-18-2013, 08:53 AM Thread Starter
I have the boom amp and the non-ultra overlay harness which has the 35 pin connector on it, the 35 pin has 4 wires coming off it that get put into the ?? pin connector on the amp, I did that and rechecked it. I put the bike back together on what my parts guy told me " it needs to be enabled on my custom" so I'll find out when I get up there, It maybe a few weeks yet, it will drive me nuts.
ZAKMANDO is offline
post #8 of 15 (permalink) Old 03-18-2013, 09:05 AM
baghrd's Avatar
When I had the Boom setup I had 2 sets of instructions. First set was to wire for 2 channel and the second set was to wire for the 4 channel (which my dealer said was a different harness). I bought it and wired up that way but only had them for about 2 weeks before changing audio routes. When wiring up for the 4 channel I had to take some pins out of the factory harness and swap into other harnesses. I think I had to do that on 4 or 8 wires. I bought it and wired up that way but only had them for about 2 weeks before changing audio routes. Those were suppose to be to make the radio have the rear speaker outputs.
I have done 3 street glides in the past month for the Boom speakers and had no problems with them, but they didnt have an amp. So idk if the extra harness that I had would fix your problem or not.
2013 Road Glide Candy Orange
baghrd is offline
post #9 of 15 (permalink) Old 03-18-2013, 11:07 AM
ENG25TRK's Avatar
Not sure what needs to be "enabled" other than the fade control.
As for your amp, there should be inputs and outputs. The inputs are where the wires go from HK Radio. The out puts go to speakers. I'm not familiar with the boom set up, but all amps are pretty much the same.
ENG25TRK is offline
post #10 of 15 (permalink) Old 03-18-2013, 11:15 AM
His parts guy got him bull shitted. Let him spend his cash.
No sound coming from new lower speakers macabra11 Audio 7 03-11-2018 06:14 PM
No Sound from Speakers EODHOG Audio 15 03-10-2016 11:03 PM
Lower Fairing speakers or Inner Fairings speakers. Looking to "thicken" my sound a bi Tvbird Audio 14 07-24-2014 10:55 PM
J&M Rokker 7.25 Speakers/No Sound bane1240 Audio 11 02-14-2013 07:22 AM
Need help: No sound from Factory Stereo when Running DED HD Audio 8 06-30-2011 08:48 AM
