Dynamat?? - Road Glide Forums
post #1 of 16 (permalink) Old 03-17-2013, 05:58 PM Thread Starter
dknapp's Avatar
Dynamat??
While cruising around the site I stumbled across a build thread where the outer fairing was lined with Dynamat. This thought never crossed my mind, not I'm curious if anyone believes this will help the sound on the bike or not?
I would like opinions. Thx
dknapp is offline
post #2 of 16 (permalink) Old 03-17-2013, 06:38 PM
For you guys answering his question do you think the dyna mat is also good for lower powered systems like Hogtunes?
Big_gary is online now
post #3 of 16 (permalink) Old 03-17-2013, 06:38 PM
Talking
currently waiting on my inner fairing to come back, but planning on doing the Dynamat myself. It is a bit expensive, but it will remove a lot of noise from rattles. Think of the kids with all the boom in their trunk and their license plates nearly rattle off. this stuff stops a lot of that....the rattles not the boom.
ricerocketroaster is offline
post #4 of 16 (permalink) Old 03-18-2013, 11:23 AM
Re: Dynamat??
Dynamat will help remove rattles for any reason it will basically be a thin layer of material that can be stuck to anything via the adhesive backing. It's going to give the mating part some density. The material is similar to refrigerator magnet sheeting.
post #5 of 16 (permalink) Old 03-18-2013, 11:36 AM
JayKS's Avatar
I believe it does help the sound, as it helps direct all the sound forward. Also, to me it's a lot better than the foam pads that come in the J&M speaker kits because it's thinner and will not interfere when reinstalling the fairing.
JayKS is offline
post #6 of 16 (permalink) Old 03-18-2013, 11:48 AM
The DynaMat is fairley dense (heavy), it might fatigue the plastic, especially around the fasteners. You don't have to cover all the surfaces to get the proper results. There are less dense (lighter) alternatives out there from other manufacturers and DynaMat. Also, you might have to cut some sections so that the fairing will fit with proper clearance.
HeatWave is offline
post #7 of 16 (permalink) Old 03-18-2013, 12:26 PM
Dynamat??
There is a spray on called lizard skin I hear is good
mirage orange 09, 21" chrome PM Heathen, 8" klock werks, 17" apes, arnott air, J&M rokkers, dresser duals with high output slipons. custom dynamics accent lights, Battistini wireframe everything
citified is offline
post #8 of 16 (permalink) Old 03-18-2013, 12:52 PM
Speaker baffles.
I used XTC 6 1/2 foam speaker baffles that isolate the sound from the inner fairing. Bass response is much improved. Little tricky getting the fairing back on. Acts like an enclosure.
Jayray is offline
post #9 of 16 (permalink) Old 03-18-2013, 01:40 PM
Neano62's Avatar
Re: Dynamat??
There is a guy down around Cincinnati, that is working on a 'Kit' for the Roadglide. He is a Dynamat supplier, and has been on a T.V. show here and there for his Hot Rod Custom Cars.
Gibson Guitars built him a Custom Shop 'Les Paul' painted to match his ride and it is freakn wicked!
I've seen it in Person.
[/IMG]
Neano62 is offline
post #10 of 16 (permalink) Old 03-18-2013, 03:44 PM
Mischief's Avatar
I used the Dynamat "Superlite". It did take a lot of the "rattle" out of the pieces of the bike when I am blasting the tunes. To be honest, the fact your not in an "enclosed space" I cant say its a must do mod, but it does help some. You dont have to go crazy though and cover the entire inside of the fairing.(i identified a few spots where it may have caused some fitment issues.) going 3 to 4 inches outward from the speaker opening should suffice. I added to the lowers and rear speaker pods also. (I have the 300 watt 6 speaker Hogtunes system)
My big concern was weight therefore my reasoning on using Superlite version and not covering the entire inside of the fairing.
2012 FLTRU
Mischief is offline
Klock Werks DynaMat Sound Control kit geo8866 Audio 11 08-27-2018 12:26 PM
Dynamat in Fairing Dsmart1 Audio 9 01-18-2018 10:35 AM
2015 + dynamat inside fairing or pods? ScreamingSkulls Audio 1 03-14-2016 03:55 PM
dynamat inside fairing bpt-bagger Audio 11 01-02-2012 01:47 PM
Dynamat installed Hotroadking Audio 17 05-11-2011 01:38 PM
