Fork Cover hitting inner fairing RF speaker - Road Glide Forums
post #1 of 10 (permalink) Old 03-20-2013, 09:01 PM Thread Starter
adam_twenty6's Avatar
just installed RF's in the inner fairing. The bolt that holds the plastic fork cover on the right side hits the speaker grill when I turn from far left to straight. Anybody else have this happen after installing RF T165's in the inner fairing?
I am going to start tinkering around trying to move the fairing to the right or find slimmer speaker grills or something. Just figured I would see if anybody else had run across it and what worked for you?
2008 FLTR 105th. thundermax, rinehart true duals, custom paint, K&N High Flow, BAL tail light, 2+2 bars, -1 rear, Hawg Wired and RF Audio, avon grips and more $hit the wife don't know about, for now....
adam_twenty6 is offline
post #2 of 10 (permalink) Old 03-20-2013, 09:06 PM
ITOLDU's Avatar
I had the same problem with the speaker grills on the Hertz speakers. I changed the bolts to button head bolts. I did t have the issue with the cover.
ITOLDU is offline
post #3 of 10 (permalink) Old 03-20-2013, 10:06 PM
Jetman's Avatar
+1 on swapping out the stick bolts to button heads. That and you have a small amount of adjustability with the fairing.
2012 - Big Blue Pearl
Heavily Accessorized.....
Jetman is offline
post #4 of 10 (permalink) Old 03-20-2013, 11:49 PM
I adjusted my fairing out a little by moving the fairing/enginge guard supports over very slightly.
post #5 of 10 (permalink) Old 03-21-2013, 06:49 AM
Neano62's Avatar
I used the 'Prime' series R/F grills.
They are very thin.
Plus I mounted the 'Whole' speaker inside the fairing.
I'm going over tonite where the bike is and I'll get some pics for ya.
All these other comments will work tho.
[/IMG]
Neano62 is offline
post #6 of 10 (permalink) Old 03-21-2013, 07:30 AM
reficul's Avatar
Re: Fork Cover hitting inner fairing RF speaker
They are very thin.
+4 I squeezed the entire speaker in the fairing. Moved the supports out a little. Switched to chrome Allen button heads and shaved down the supplied speaker grill with a utility knife. Looks and fit great. I shaved off that entire 1/4" edge
2012 Shark Face
One day he is gonna answer
reficul is offline
post #7 of 10 (permalink) Old 03-21-2013, 08:37 AM Thread Starter
I am going to try the smaller headed bolt and moving the fairing out a little with the support bracket. I would move speaker inside fairing, but I cut the whole too far back, and speaker is tight fit already, giggidy. If those don't work, the grills will be shaved or replaced. Wish I could find a wire mesh grill like that guy on here makes for the factor location speakers. That would be cool.
Added note, a 5" whole saw makes the perfect diameter hole for the RF's. Inner fairing comes off easy...
post #8 of 10 (permalink) Old 03-21-2013, 09:01 AM
Zog
Zog's Avatar
If you have stock lower fairing support just loosen up the 2 hex head bolts a little that are around the engine guard/ crash bar you can get a lot of clearance by just pulling them out a bit and retightening.
Edit k i see you already said you would try that. probably wont need the bolts if you move the support first. yours is a lot closer than mine was though. Best of Luck
2009 Black pearl 110ci,D&D exhaust, titanium gauges, Bright ass lights tailight, madstad windshiled, jac-knife highway pegs, progressive monotones, Ness Deep Cut Hot Legs etc..etc..etc...
Zog is offline
post #9 of 10 (permalink) Old 04-02-2013, 09:58 AM
rdrnr03's Avatar
I will hopefully get my speakers and amp this weekend. I will atemp to cut holes with inner still installed. If it won't work I guess I will have to remove it.
rdrnr03 is offline
post #10 of 10 (permalink) Old 04-03-2013, 06:51 AM Thread Starter
4 nuts is all. Have to pull 2 for amp bracket anyway. Label wiring connections as you pull them apart. Hole saw and done.
Rockford Fosgate Inner fairing Fork Speaker Replacement Jwasielczyk Audio 4 09-13-2015 05:53 PM
fork oil change, hitting hard ironmike666 Troubleshooting for Road Glides 7 06-09-2015 06:25 AM
Hawg-Wired 6-Pack + RF 165 Inner Fairing Install - with Pix Slider57 Audio 8 04-20-2014 01:09 PM
RF Amp Inner Fairing Mounting Plates Q-Hog Sold 3 01-27-2013 08:29 PM
RF PBR300x4 amp and RF speakers? GLYDDN11 Audio 2 02-02-2012 09:46 PM
