Where is the best place to ground your amp inside the fairing - Road Glide Forums
post #1 of 5 (permalink) Old 03-22-2013, 03:03 PM Thread Starter
sdlakerfan79's Avatar
Where is the best place inside the fairing to ground your amp? I'm going to relocate it inside the fairing. Its currently in the saddlebag, and is grounded to the main grounding point near the battery. I've heard that the ground wire should be as short as possible. I don't know why that is. But that being said, since im moving it into the fairing, I'm trying to stay away from having a longer ground cord from the fairing to the battery. I'd like to find a nice spot inside the fairing to ground the amp to.
Suggestions please.
sdlakerfan79 is offline
post #2 of 5 (permalink) Old 03-22-2013, 03:05 PM
Mischief's Avatar
I used one of the bolts that hold the inner fairing to the chassis.(near the opening for the headlight adjustment) worked for me for all of last year.
(Right or wrong, I wired a dedicated ground from the battery to the amp this year)
2012 FLTRU
Mischief is offline
post #3 of 5 (permalink) Old 03-22-2013, 04:10 PM
h-donut's Avatar
+1
that position should work, had mine grounded there for a year, then once those bolts were all 4 holding amplifier brackets, moved my ground to the neck
but I wouldn't try and squeeze that amp in, it will cause your fairing to bulge, ask me how I know.
2010 FLTRX- r o a d g l i d e
h-donut is offline
post #4 of 5 (permalink) Old 03-22-2013, 04:17 PM Thread Starter
hmm. heat... yeah, i guess if I tried to squeeze it in there it def' could bulge. i'll have to find another place where it could go.
post #5 of 5 (permalink) Old 03-22-2013, 04:24 PM
h-donut's Avatar
well, you might as well try, but I'd check the fitment first B4 wiring
h-donut is offline
Are both your forks centered with the inside of the fairing? Crazyhog *General Road Glide Discussions/Pictures 15 04-27-2015 08:33 PM
Best place to buy amp + speakers? Craigmier Audio 10 04-06-2015 02:13 PM
Best place to buy J&M speakers LUCKY13 Audio 15 10-05-2013 02:42 PM
J&M Inside Fairing Acoustic Speaker Pads FLTRXS18 *General Road Glide Discussions/Pictures 7 07-03-2013 09:32 PM
