2012 Road Glide MP3 Read Issues. HELP!! - Road Glide Forums
post #1 of 17 (permalink) Old 03-25-2013, 05:55 AM Thread Starter
nhga47's Avatar
Talking 2012 Road Glide MP3 Read Issues. HELP!!
Hello everyone,
I was wondering if anyone else is experiencing problems burning MP3 disks that will play in the 2012 Harmon Kardon radios? I am getting quite frustrated as none of the formats and speeds I have used seem to work. It constantly comes up with a disk error. Any knowledge on this would be greatly appreciated. Thanks in advance for your time!
From my COLD DEAD HANDS!
nhga47 is offline
post #2 of 17 (permalink) Old 03-25-2013, 01:39 PM
Its been awhile but the last one I did I had to remove the art work and that seemed to work. What are you using to make the cd?
Mark
Mhenning is offline
post #3 of 17 (permalink) Old 03-25-2013, 01:46 PM
PGR
PGR's Avatar
Download this http://www.mp3tag.de/download.html and remove all the tags. Then throw the MP3s on a CDR and burn it as a data CD.
Ron..........................
PGR is offline
post #4 of 17 (permalink) Old 03-26-2013, 01:50 AM Thread Starter
nhga47's Avatar
Gents,
I have tried using Roxio, Itunes etc, and burning at the slowest speed possible which I hear is a problem at higher speeds. I will try the tag remover and see if that works for me. What a pain in the ass. Thank you both for your help and response. I am using my desktop pc to burn the disks.
nhga47 is offline
post #5 of 17 (permalink) Old 03-26-2013, 02:23 AM
sdlakerfan79's Avatar
The problem is the album art embedded in the mp3. Go in itunes.. remove the album art from all the mp3s you want to burn on the cd. I've tested this. The problem is 100% album art in the mp3.
sdlakerfan79 is offline
post #6 of 17 (permalink) Old 03-26-2013, 02:58 AM Thread Starter
nhga47's Avatar
Thank you! I will give that a shot! Much appreciated! I guess these HK radios are a bit picky! Thanks to everyone for the help!
nhga47 is offline
post #7 of 17 (permalink) Old 03-26-2013, 05:28 AM Thread Starter
nhga47's Avatar
Talking argh!
Ok, so I tried removing all tags from the songs that I wanted to burn. I then burned as a data cd. Still no dice. So now when I have time I will have to go in and remove the art and see if that works. Seriously, they all play in my car stereo. Harmon Kardon sucks!
nhga47 is offline
post #8 of 17 (permalink) Old 03-26-2013, 05:50 AM
PFWiz's Avatar
Re: 2012 Road Glide MP3 Read Issues. HELP!!
Just search mp3 or burning with my name. I copied a write up i founnd that explains step by step how to make discs with 70 - 100 songs. I will copy it tonight after i get back from work.
PFWiz is offline
post #9 of 17 (permalink) Old 03-26-2013, 09:03 AM
598Malibu's Avatar
Subscribing
2012 Big Blue Pearl FLTRU
72 Chevelle with Procharged 598
598Malibu is offline
post #10 of 17 (permalink) Old 03-26-2013, 09:13 AM
Paul's Road Glide's Avatar
Album art is an issue, but not the end cure. In itunes when you burn the itune file to a playable cd it burns it in its current version. The HD HK stereo doesn't recognize it. You will need to first convert the itunes file to an .mp3 file, once you do that then select all files and right click and then select convert ID3 tags to the lowest version, probably 1.1.
Paul's Road Glide is offline
TBW Issues Explained by HD Service Bulletin TT418A a MUST READ ironmark Troubleshooting for Road Glides 16 11-13-2016 07:08 AM
2013 RoadGlide 21" Wheel Issues Please Read 1RADTOY Wheels and Tires 12 11-21-2013 03:04 AM
I've read and read and still confused. Advice needed. miztrz99 Audio 10 05-02-2013 04:13 PM
HK MP3 help Paul's Road Glide Audio 5 08-30-2012 08:38 AM
Issues with the mp3 player..... ybnorml *General Road Glide Discussions/Pictures 9 07-28-2010 08:52 PM
